speedometer not working
Old Aug 29, 2003 | 12:55 PM
Young_R's Avatar
Default speedometer not working
i did search and i seemed to find info that is not related to my problem.
i have had canadian type r and i tried to changing out speedometer and it is not moving anymore. what do i need to do? thanks for help.
Old Aug 29, 2003 | 01:00 PM
yoshi234's Avatar
I shoot brides
Default Re: speedometer not working (Young_R)
my speedo starting sticking couple months ago, so I just replaced it w/ a sp00m clustah
Old Aug 29, 2003 | 01:04 PM
RTW DC2R's Avatar
Default Re: speedometer not working (yoshi234)
did you plug everything back in when you put the cluster back in? are all the lights working on the cluster? did you remove the needle on the speedo?
Ryan, who wonders why he was trying to take out his speedo?
Old Aug 29, 2003 | 01:05 PM
Young_R's Avatar
Default Re: speedometer not working (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">did you plug everything back in when you put the cluster back in? are all the lights working on the cluster? did you remove the needle on the speedo?
Ryan, who wonders why he was trying to take out his speedo? </TD></TR></TABLE>
yes we plug everything back in.
all the lights work. rpm reading works find etc. etc.
i wanted to take out the speedo in order change km/h to mph.
Old Aug 29, 2003 | 01:45 PM
Young_R's Avatar
need help asap
Old Aug 29, 2003 | 02:24 PM
skafia's Avatar
25 Year Member
Plug in another cluster to see if it works, if it does, then you have a bad cluster... Get a Gaydm one
Old Aug 29, 2003 | 03:23 PM
onyx00's Avatar
Default Re: speedometer not working (skafia)
Does the odometer work? If not, then it is a power problem. If it does, thne the speedometer is sticking.
Old Aug 29, 2003 | 03:41 PM
Young_R's Avatar
Default Re: speedometer not working (onyx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">Does the odometer work? If not, then it is a power problem. If it does, thne the speedometer is sticking.</TD></TR></TABLE>
yes odometer do not work either
Old Aug 29, 2003 | 04:26 PM
jetydosa's Avatar
25 Year Member
My VSS (vehicle speed sensor) goes out occasionally and when it does my speedo and odo stop working. Everything else works fine....do you have a CEL or anything?
Old Aug 29, 2003 | 07:03 PM
Young_R's Avatar
Default Re: speedometer not working (Jetydosa)
anyone?
Old Aug 29, 2003 | 07:08 PM
Dan GSR's Avatar
did u touch the needle?
if so try pushing it in....and then pulling it out a lil
just sounds like ur needle got fugged
Old Aug 29, 2003 | 09:07 PM
baonest1's Avatar
Default Re: speedometer not working (Dan GSR)
check the VSS
Old Aug 29, 2003 | 09:18 PM
all stock's Avatar
Default Re: speedometer not working (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">check the VSS</TD></TR></TABLE>
Old Aug 29, 2003 | 09:25 PM
Young_R's Avatar
Default Re: speedometer not working (all stock)
checking
Old Aug 30, 2003 | 08:04 AM
K20DC2R's Avatar
if your vss is bad a check engine light would be on so its most likely the gauge probably. good luck ! what kinda gauge u put in? jdm?
Lev8177
Aug 5, 2014 04:04 PM
LokilloJdm
Jan 28, 2009 06:55 PM
slow_cx
14
Dec 10, 2007 10:08 PM
rev210k
Feb 3, 2006 08:35 PM
MassScene
Mar 18, 2005 06:46 AM
