Cryo Cams ???
Old Aug 29, 2003 | 10:53 AM
mahalo motorsports's Avatar
Default Cryo Cams ???
If "some" cams are prone to breaking, why couldn't you cryogenicly treat the cam as you would a crank/piston/rod.
did a search, couldn't find anything (The search features suck ***)
Old Aug 29, 2003 | 11:25 AM
SuperTwinz's Avatar
Default Re: Cryo Cams ??? (Hemi Ram)
I say 80% of cam breakage is due to operator error.
Modified by Supertwinz at 1:58 PM 8/29/2003
Old Aug 29, 2003 | 12:11 PM
dmotoguy's Avatar
Default Re: Cryo Cams ??? (Mr. Displacement)
i think there was a post about this a long time ago, but the new search really isnt as good as it used to be
Old Aug 29, 2003 | 12:28 PM
Default Re: Cryo Cams ??? (dmotoguy)
"Why would you purchase cams you have to cryo treat?"
Because... "some" cams are prone to break.
Jun III's (start flaming)
These cams have been known to break even when all clearances/ Install height /spring pressure have been checked. I think cryo treating would be cheap insurance for the few who got a hold of some used cams, (providing that the cryo process does not warp or change the dimensions of the cam) <------ my real question.
Old Aug 29, 2003 | 12:41 PM
F1's Avatar
F1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hemi Ram &raquo;</TD></TR><TR><TD CLASS="quote">
These cams have been known to break even when all clearances/ Install height /spring pressure have been checked. I think cryo treating would be cheap insurance for the few who got a hold of some used cams, (providing that the cryo process does not warp or change the dimensions of the cam) &lt;------ my real question.
I see your point in the question now.
So if someone were to give you cams, personally I would sell them to help me save money for new un-used cam(s).
See Bold.
http://www.metal-wear.com/racing.htm
Cryogenic processing is not a substitute for heat treating. You still have to heat treat the part. Poor heat treating will result in poor parts, even with cryogenics. That is why we work with our industrial customers to assure that their heat treat is the best.
Cryogenic processing is not a coating. It affects the entire volume or the part. Parts can be reworked or sharpened after treatment without need to retreat
Cryogenic processing is not "cold treating" done to bring up the hardness of badly heat treated components.
Cryogenic Processing is not a simple dunk into liquid nitrogen.
Cryogenic processing is a metallurgical process that when used with good metal and good heat treat will result in superior wear resistance in most parts.
area522010
Jul 17, 2010 01:06 PM
slowkaos
Dec 12, 2004 07:23 PM
foma2.2
May 21, 2004 10:46 AM
MugenGTR
Aug 31, 2002 10:51 AM
evo
Dec 20, 2001 03:37 PM
