Changing driver side axel 97 b16 civic
Old Aug 29, 2003 | 10:20 AM
purpl7duece's Avatar
Default Changing driver side axel 97 b16 civic
Okay my friends axle was popping so he asked my other friend if he could change it. Anyway he goes to pull it out and part of it comes out. when it came out the bearings (i think) were exposed. I thought the axle was stuck so I asked a mechanic at the shop across from mine if he had any idea to get it out. He told me that i had to take off two bolt and it would come out then. The thing I pulled out has a bearing on it and a bracket that attaches to the block Then a long *** shaft that i guess goes in the tranny. my ? is how do we go about getting that bracket off? and put a new one in? The car is a 97 civic 4-door with a 99 US B16 and 98 GSR front suspension if that helps. I am pretty new to workin on Honda's and wish they were as easy as old school cars.
ANY HELP IS APPRECIATED
Old Aug 29, 2003 | 12:37 PM
Aceman64's Avatar
Default Re: Changing driver side axel 97 b16 civic (purpl7duece)
I dont know which bracket you are talking about, but if the axle is stuck just use a pry between it and the intermediate shaft or place where its stuck. There are little metal rings aroung the splines that lock it in place.
-Ace
Old Aug 29, 2003 | 01:59 PM
Default Re: Changing driver side axel 97 b16 civic (Aceman64)
i found out that they shaft with it is the intermediate shaft. I guess I am gonna have to pry the **** out of it. I hope.
Old Aug 29, 2003 | 02:09 PM
Aceman64's Avatar
Ok, just get a pry bar and pry between the two. That is how I always remove axles that wont pull out.
-Ace
Old Aug 29, 2003 | 04:51 PM
Mike P.'s Avatar
25 Year Member
Leave the intermediate shaft on the car where it is, and use a nice 3lb sledgehammer. Getting your aim right, you can smack the CV axle strategically to where it'll be separated in 5 seconds. I had a helluva time with this last week, until I tried the hammer approach. Who cares if you screw the old axle up with a sledgehammer?
nuber1zero
Jun 19, 2014 07:30 PM
manuiacoban
13
Apr 9, 2010 11:43 PM
GoodEyeSniper
Feb 19, 2009 02:21 PM
hardvtec90
Sep 21, 2008 07:51 PM
pikappaphi
11
Oct 17, 2003 11:39 AM
