Initial timing on Mini-me
Old Aug 29, 2003 | 10:03 AM
Renegade's Avatar
Default Initial timing on Mini-me
Any suggestions or recommendations to setting the timing after installing the head?
Or any other things I will need to do before starting the car?
The Z6 head has an adjustable cam gear, I forget which one will need to go home and look at it if anyone needs to know.
Thanks
Old Aug 29, 2003 | 10:28 AM
USDM 4G VTEC's Avatar
Default Re: Initial timing on Mini-me (Renegade)
since the Z6 head will be half a tooth off in the timing,
make sure u got that cam gear on 4.75 degrees advanced... that way u will actually have it on 0 cam degrees
Old Aug 29, 2003 | 10:29 AM
91civicEX's Avatar
right now mine is advanced 5 degrees. thats not the most powerfull position for sure but it runs and drives normally. i have a 1.5 block and a z6 head. it also has an aftermarket cam though but it should be around the same for you.
Old Aug 29, 2003 | 10:35 AM
Renegade's Avatar
Default Re: Initial timing on Mini-me (91civicLX)
advance is counter clockwise and retard is clockwise?
Old Aug 29, 2003 | 02:36 PM
91civicEX's Avatar
it should have marks. but to advance turn the crank clock wise and to retard turn the crank counter clockwise. it seems wierd but trust me youll see why its like that.
Old Aug 29, 2003 | 04:02 PM
CimorelliCRX's Avatar
Which bolt does everyone use for the distributor? Top, right or left? I have mine in the one closest to the front of the car(right one). I am planning OBD1 here in a little bit, hopefully as soon as I can find a P28 ECU for around 100 bucks(anyone have one, hit me up).
Old Sep 1, 2003 | 04:37 PM
91civicEX's Avatar
i had a zip tie cuz none of the bolts would line up. it held up fine and ran but i finally decided to go obd1
#Leo#
May 20, 2010 11:17 PM
bushfreakz
Sep 13, 2006 10:58 AM
wantasol
Jul 8, 2006 09:16 PM
O16581724 5 2 5
Jul 5, 2006 07:29 AM
d15maverick
May 3, 2004 09:14 PM
