What do I need to have Toda C running....
What pistons, other that toda i can use with the spec C. I also wanted to know all the parts i would need to have this running good......
CTR pistons have enough clearance. All the parts? Umm Toda springs, injectors, good header/test pipe and lots and lots of tuning. THose are minimum requirements.
CTR Pistons will give you 12.2:1 in an ITR or 12.6 in a GSR
I'd reccomend
larger injectors
FPR
Short Ram Intake
Spoon or Toda Header
TI Retainers
Toda camgears & valve springs
J&S Safegaurd
and either a chipped ecu or even better a Hondata or Power FC and Dyno Tuning
I'd reccomend
larger injectors
FPR
Short Ram Intake
TI Retainers
J&S Safegaurd
I spoke SGT about the very same thing. He told me the AEM CAI style intakes made more power up to 4500 rpm's. After that the short ram style (specifically the ITR pipe that runs to your airbox with a K&N filter on the end) made more after 4500 rpm's. He dyno tested the two intakes.
I'd tend to take his word for it. He's one of the two fastest all motor ITR's on the board.
Well each car is different. We also tried a cold air setup compared to the short ram and lost significant power on the short ram with Spec C's. I guess buy two intakes, test and sell the one with less power.
CTR's have enough clearance?? Might want to look into that or clay it up before you drop those in with the C's as far as the ecu...POWER FC ...very user friendly
and would be worth the money in the long run
Just my 2 Yen
Just my 2 Yen
AllMotorDan
62
Aug 13, 2012 07:38 AM
JDM TypeR 307
Dec 29, 2003 02:13 AM
hybridsedan
May 23, 2003 04:29 AM
powerfulperformance
Apr 13, 2002 06:47 PM
