Jus passed 30 k miles. Need tune up info.
Old Aug 29, 2003 | 06:24 AM
Opie's Avatar
Default Jus passed 30 k miles. Need tune up info.
Hey like the title said I just passed the 30k mile point in my R. Wanna tune it up, just not sure what I need @ this point. Called a local dealership, they wouldn't talk to me cause I'm not bringin' the car there. Just changed my oil, and ordered a new fuel filter. What about cap rotor plugs & wires? If so, would MSD be the right way to go?
thanks
-->opie
Old Aug 29, 2003 | 06:57 AM
baonest1's Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (opie112)
if its a stock motor. then factory cap/rotor, plugs, fuel filter, check all belts, dont know if you wanna check the tranny fluid.
im sure others will chime in.
what parta NY?
Old Aug 29, 2003 | 07:01 AM
oryanh's Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (baonest)
I recently changed my tranny fluid @ 28K miles, to only find I could have bottled it and sold it back to Honda. -the stuff was crystal clear.
PCV valve could be changed as well. You may also want to do a valve adjustment, and check your wheel bearings. -i'm old school.
Old Aug 29, 2003 | 07:08 AM
Opie's Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (oryanh)
Would it hurt changing to an MSD cap and rotor? About as expensive as stock.
Old Aug 29, 2003 | 07:11 AM
ultimatehonda's Avatar
I think the msd cap is for when you are using a external coil. If you have msd then u would need that but if u are stock then just go with the oem.
baonest1's Avatar
if anything, it would help i beleive.
Old Aug 29, 2003 | 07:24 AM
Opie's Avatar
MSD makes an external blaster coil that does replace the oem coil. You do need to switch to ther coil if you use there cap. Ithink im stickin to oem and changing to msd wires and ngk platinum plugs.
Old Aug 29, 2003 | 07:29 AM
vtec.dc2's Avatar
oem wires are sumitomo and not msd.. besides whats already listed, i'd suggest valve adjustment and transmissoin oil change, coolant change.. - thats if you wanna keep your car in good shape.. i do these things every 15k miles
Old Aug 29, 2003 | 12:06 PM
NewR's Avatar
I did mine last weekend and I followed the to do list from itrsport.com
15,000 Mile Service
Change Engine Oil and Filter - Done at 29K miles
Inspect and Service Front Brakes – Replaced front rotors and Axxis Ultimate break pads.
Inspect Rear Brakes – Replaced with Axxis Ultimate break pads.
Adjust Parking Brake – Checked and ok
Inspect Brake Hoses and Lines – Inspected and ok
Inspect Anti-Lock Brake System – Inspected and ok
Adjust Clutch – Not needed
Inspect Power Steering System, Tie Rods, CV Boots - Inspected
Retorque Suspension Mounting Bolts - Done
Rotate and Balance Tires – Replaced all four tires (Azenis)
Check Tire Pressure and Fluid Levels – Done
Adjust Valves – Valve Clearance Ok, also checked Timing and within spec.
Align Front and Rear Wheels -
Change Transmission Fluid – Replaced with Honda Transmission fluid
Inspect Throttle and Transmission Cables - Inspected
Flush and Replace Anti-Freeze (Not Required at 15,000) – Flushed and filled with Prestone Coolant
30,000 Mile Service (Repeated at 60000, 90000, 120000, etc.) Includes All Items of 15,000 Service Above Except Flushing of Anti-Freeze - Plus the Following
Service Anti-Lock Brake System (Except RS) -
Change Brake Fluid -
Inspect Exhaust System - Inspected
Adjust Alternator and Power Steering Belts – Not needed
Change Transmission Fluid - Done
Replace Air Filter – Replaced with Factory Filter
Replace Spark Plugs (GS-R and Type R Every 60,000 Miles)
Replace Ignition Cap and Rotor (Except Cap at 30,000) – Replaced with Factory Ignition Cap & Rotor
Replace Fuel Filter – Replaced with Factory fuel filter.
My timing is set 18deg from the Factory.. I have not touched the timing since I bought the car new. Is this normal?
Old Aug 29, 2003 | 02:25 PM
B2FiNiTY's Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (NewR)
New timing is 16 +/- 2 sometimes.
Old Aug 29, 2003 | 02:39 PM
uNF$@#!'s Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (B2FiNiTY)
how the hell do you service the ABS system?
Old Aug 29, 2003 | 02:40 PM
Chris N's Avatar
Default Re: Jus passed 30 k miles. Need tune up info. (Soup ****)
Timing spec in the helms is 16 degrees +/- 2, so you are ok.
Old Aug 29, 2003 | 02:54 PM
NewR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">how the hell do you service the ABS system? </TD></TR></TABLE>
I was wondering the same thing, that was why i left it blank. Does anyone know how?
wastedyouth2542
Dec 23, 2009 05:27 AM
Opie
Sep 29, 2003 08:43 AM
BikeSpike
Aug 26, 2003 08:21 PM
sohc_boy
12
Jul 29, 2003 04:24 AM
vtecdc2
Jul 15, 2002 06:41 AM
