what cams would fit with this setup
Just wondering what cams I should be looking at I was about to buy some ITR 01's but now I am looking into some skunk2 stage 2 but don’t know if I will have the clearance to put them in and would the valvetrain I already have be fine. Any help would be appreciated
my set up
b18a block
LS rods and crank
CTR pistons
2 layer head gasket (12.6:1) i think
GSR head with mild clean up and porting done
JG stainless valves, springs and retainers
Skunk2 intake manifold with h23 throttle body
and hondata s200 with an ITR modified program
I am also thinking on getting the Apexi GT header with 2.5 collector
I am just having problems choosing what cams should to get I know that I can run the 01 ITR without anyd problems but as for the skunk2 stage 1 or stage 2 i dont know if it would clear
Thanks
Modified by jdmcx at 1:00 PM 8/29/2003
my set up
b18a block
LS rods and crank
CTR pistons
Thanks
you would want to go with the skunk 2 stage 2's since you have the compression to make really good gains from them, although you need to check clearances before making a purchase, skunk 2 stage 1's should have no problem clearing though.
Jun stage III loves high comp too. seek ye info at http://www.team-integra.com or net
hybrid69
Jan 20, 2005 04:40 AM
B16Hatchcx
Dec 24, 2003 02:20 PM
juggernaut
Oct 5, 2003 06:05 AM
