serious problem after tranny fluid swap
Old Aug 29, 2003 | 12:08 AM
civicgsr91's Avatar
Default serious problem after tranny fluid swap
well i decided to change my transmission fluid after reading the post about the gm synchromesh.
i drained the fluid and just could not get the fill hole bolt to open so i could fill it up. so i decided to go through the speedo sensor on top of the transmission.
take that off fill the transmission up with 2.5 qts of synchromesh. then put everything back together again.
start it up and it idles loudly, but steady. then CEL turns on. take my car for a ride and i cant get past 3300 rpm.
so i go to check the code, but the CEL only comes on when the car is running. when i turn the ignition on the CEL doesn't come on. so no flashing. i am going through everything and double checking but cant figure it out
any help would be appreciated.
Old Aug 29, 2003 | 04:31 AM
2000vsm's Avatar
Default Re: serious problem after tranny fluid swap (civicgsr91)
why coudln't u get it open, it's so easy, even more easier than oil change... just use a hose and funnel to fill it up... go under the car to break open the filler bolt or even above,... my car is a 2000 civic ex.. what is yours?
Old Aug 29, 2003 | 05:08 AM
dip-set's Avatar
Default Re: serious problem after tranny fluid swap (2000vsm)
old tranny fluid can make the car sluggish correct..?
Old Aug 29, 2003 | 06:06 AM
StyleTEG's Avatar
Default Re: serious problem after tranny fluid swap (teg-your-it)
I would double check and make sure your speed sensor is connected, torqued down correctly, its not loose, etc
I would bet money that the speed sensor is the code flashing.
Old Aug 29, 2003 | 07:09 AM
Stripped Honda's Avatar
99-0104
Default Re: serious problem after tranny fluid swap (StyleTEG)
i also agree it probally the speed sensor pull it out and re-install it make sure the conector is clipped in and reset your ecu
Old Aug 29, 2003 | 10:28 AM
Aceman64's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">so i go to check the code, but the CEL only comes on when the car is running. when i turn the ignition on the CEL doesn't come on. so no flashing.
Hook up the connector with the car running then and get the code. If you only messed with the VSS then I'm sure it has something to do with it.
-Ace
Old Aug 29, 2003 | 03:29 PM
pythonScott's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">old tranny fluid can make the car sluggish correct..?</TD></TR></TABLE>
no, not exactly. You may experience losses due to more friction in the drivetrain b/c the viscosity of the fluid is shot, but it's hardly something I think you'd notice.
Old Sep 2, 2003 | 09:40 AM
civicgsr91's Avatar
Default Re: serious problem after tranny fluid swap (pythonScott)
UPDATE:
got another vss from honda junkyard, installed still same problem.
trying to check what code it is throwing but cant. the cel turns on then off when car is turned on. but when i start it the cel stays on no flashing.
i am using the paperclip technique into the plug behind the glove box. and nothing.
car will not let me rev past 3300 rpm. and i have no idea why.
what would cause that? please help!
Old Sep 2, 2003 | 09:51 AM
dip-set's Avatar
i dont know if anyone mentioned this..but the cel is flashing for a reason..
Old Sep 2, 2003 | 10:35 AM
Muckman's Avatar
Moderator in Chief
Maybe your not doing it right. You jump the service plug then turn the ignition to ON, you dont start the car.
Old Sep 2, 2003 | 12:22 PM
civicgsr91's Avatar
Default Re: serious problem after tranny fluid swap (Muckman)
i am getting code 16 fuel injection system.
i checked my main relay and that is working. i am getting fuel pressure which is being indicated by the car starting and my fuel pressure gauge reading what it did before.
my car will not hold a charge. i have to always jump it to start it. alternator? battery?
what else can i check?
Modified by civicgsr91 at 11:41 PM 9/2/2003
Old Sep 2, 2003 | 02:57 PM
civicgsr91's Avatar
still need help
ttt
jmai86
Jul 6, 2012 03:39 PM
danielm213
Dec 16, 2011 11:22 AM
philkehn
Jan 21, 2007 05:03 AM
TrueUntilDeath.com
Aug 9, 2004 08:26 AM
Ants
Mar 18, 2004 06:27 PM
