Help....ZC wiring diagrams...?
Tried a search for all you who want that info...nada....heres my problem
-I just got done w/ my swap and I have one wire left that doesnt seem to go anywhere. I know its seems stupid, but I went through and tried to find what it could connect too. Heres the wires Im talkin about....
Its in the loom thats connected to the:tranny ground-radiator plug(green), a white plug also(cant figure out where that plugs in), and the remaining wire is red(power, but where) It has a but-connector attached and I think one of my helpful friends yanked it off "helping" me try and do the swap (last time I let him near my car!). I need a wiring diagram of all the wires coming from the fuse box on the strut tower...thats where they all lead to.
If anyone could provide a pic/link(tried MANY searches on google/went to zcr/etc and I cant find ****. I really need to know what these connect to b4 I get my car back on the road.
if you're doing a dx to zc swap, then they're should be 3 plugs left over. here's a link http://www.88-crx.com/ZC_Page/...p.htm
im assuming you did the wiring correctly like on this website: http://www.zcspeed.com/wiring.htm
All the wiring is correct...the two wires are a green wire by the i/m (I think thats the o2 sensor hook up) and then a red wire connected to the tranny ground and radiator plug. I believe that wire would go to a plug by the dizzy, but its a black wire? Power to Ground?...Fukin aggro!!!!If anyone could take a pic of their swap and show me cuz the earlier links dont show what wires Im talkin about....I need to know where the o2 sensor wire connects and to see all the wires in the loom that connect to the radiator plug in and tranny ground.....
I need a close up of that pic, a pic to the left where the green radiator plug is and of where the o2 sensor goes...appreciate it....I think I have it all figured out but Im waiting for a new battery now neway....grrrrrr...aggro!
Green with what color? Green/white is a common sensor power wire from the ecu that goes to many sensors on the motor. O2 wire is a white shielded wire. The plug on the head is a 1wire for the instrument cluster temp gauge and a 2 wire ecu temp sensor. Fan is the two prong temp senor on the back of the block. List all the wire colors and we'll see what we can do. Did you add your CYL position sensor wires? BLU/YLW, BLU/GRN? And another hint all the pins in the B and C connectors do not need to be cut they can be removed with a small scrtewdriver or Honda pin extractor tool. That saves alot of aggravation. Same with the TPS sensor wire there is alot of extra wire in the harness if you pull the harness apart from the drivers side over to the position of the bolt on wiring mount on the thermostat housing that leaves more than enough extra wire for the TPS sensor.
Never mind on that green wire comment. The only plug that doesn't go to anything anymore is the fast idle solenoid for Sis I forget what they call it on the DX orange/some other color wire.
Basically the three wires are the one off the o2 sensor-I need to see where that goes-a black wire that comes off a plug by the dizzy and a red wire by the tranny ground...lmk
I have that plug undone-thanks for that. I need a close up of the wire in the other pic..thats one thats left open and then a pic of the wires attached to the same loom as the tranny ground/radiator plug and open wire?..I appreciate teh help..+ I need to see where to o2 wire fits to...thanks..
Spaceballsthelunchbox
Welding / Fabrication
Jun 21, 2005 06:04 AM
