BG44K -- Anyone ever used this Carbon cleanser?
My father was told to try this stuff on his truck. 85 S10 with high mileage. Anyhow, he says Honda dealerships sell it and it's used in Volvo and BMW cars.
It's suppose to remove the carbon from the injectors, IM, valves, and cylinders.
http://bgprod.com/bgconsumer/bgservices/44k.html
You only use it when you can empty the full tank within 2 days. On the way to Nopi in Atl. will be a good time I think
Then it's recommeded to change the oil afterwards. Will do that when I return from Nopi
Anyhow, does this $hit work?
There's also another cleanser my dad has some info on. It's called Ventil Sauber Valve Clean. It's cheaper at about $7 a bottle compared to the $18 for the BG44K.
