How to remove 95's bumper?
Old Aug 28, 2003 | 06:09 PM
ForceXVII's Avatar
Default How to remove 95's bumper?
Does anybody know how? thanks
Old Aug 28, 2003 | 06:29 PM
AccordOn18z's Avatar
Default Re: How to remove 95's bumper? (ForceXVII)
Be Prepared for a fighting battle....First off you will have 3 or 4 pushpins (plastic) on the top of the bumper you will not see these till you take off your middle grill which is 2 or 3 screws after the plastic pushpins...turn your wheels to the left and theres a 8mm screw at the corner of the bumper where the fender meets the bumper this will be on both sides...when you take them off you will have a little flex in the bumper so you will have to pull a little and loosen the bottom of the headlights beacuase under the headlights is 2 or 3 more pushpins on both sides after that....do what your gonna do and reverse these instructions and you should be set...hope i helped later
Old Aug 28, 2003 | 07:52 PM
ForceXVII's Avatar
Default Re: How to remove 95's bumper? (AccordOn18z)
How do I loosen the screw on bottom of the headlight? Its hard to reach in. Thx
Old Aug 29, 2003 | 09:22 AM
kue_ek's Avatar
i am a noob but i think you just remove the bumper lights. then when that is removed in the back their will be 4 big screws on each side that hold the bumper on. take those off then the bumper should come off. don't forget bout those push screws on the bottom.
Old Aug 29, 2003 | 10:09 AM
95blk2draccordEXMT's Avatar
Yep I did it to paint my headlights on my 95 ex... just take the screws off the top, the bolts off the bottom the screw like the first guy said. Then take out the bumper blinker light and there are 4 bolts inside just like that guy said... It'll be really hard to reach unless you got a pretty long extension in your ratchet set. I think it's 12mm, if not then it's 10mm. for a better explaination... here's a good guide:
http://www.andrews.edu/~johnso....html ... thanx to cyrogen :-)
Old Aug 29, 2003 | 11:21 AM
ForceXVII's Avatar
Default Re: How to remove 95's bumper? (95blk2draccordEXMT)
Thanks all, very useful link
gcturismo
Jan 19, 2008 07:50 PM
Jer'rome
Honda Civic (2001 - 2005)
May 27, 2007 05:57 PM
StreetGlwLude
Sep 20, 2004 04:49 PM
95se4dr
Aug 5, 2004 10:39 PM
kappi84
Oct 10, 2002 11:07 PM
