Can I drive 200 miles to the dyno on my untuned B18C5 w/ Toda C's safely?
Old Aug 28, 2003 | 05:25 PM
MEANB18's Avatar
Default Can I drive 200 miles to the dyno on my untuned B18C5 w/ Toda C's safely?
I'm just curious if I will be safe driving 200 miles to the dyno on my current setup which is untuned at this time? I'm basically just running Toda Spec C's w/ portflow valvetrain, milled head, mugen two-layer headgasket, stock USDM ITR bottom end. I have the S200 system, but it's not really tuned at all. Is it safe? How bad will gas mileage be? Would be it be smarter to just pay a friend to tow it there?
I'm looking for ANY suggestions at this point, I want to have the car tuned hopefully for next weekend!
-Brian
Old Aug 28, 2003 | 05:28 PM
91tegrals's Avatar
if its so bad youre worried about driving 200 miles then i wouldnt drive it at all and get it towed. but how does it run while youre driving around town..
Old Aug 28, 2003 | 05:35 PM
Patch's Avatar
Default Re: (91tegrals)
Gas mileage would be the least of my concerns. I say as long as you stay out of VTEC, you'd be alright.
Old Aug 28, 2003 | 05:54 PM
viprcr1's Avatar
Default Re: (CRX PAT)
wouldn't it just run really rich.
Old Aug 28, 2003 | 07:49 PM
MEANB18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">if its so bad youre worried about driving 200 miles then i wouldnt drive it at all and get it towed. but how does it run while youre driving around town..</TD></TR></TABLE>
Last night was the first time I started the car with the new cams, and just drove it around the block. When I would get to around 2700 rpms, it would start to sputter and cut out a little. I didn't go much higher than 3200 rpms really. I have a couple more things that need to be done the the car before I can drive it around town much. Mind you, I'm still on the stock injectors which is probably the reason for the car sputtering soo much. (plus having a stock P28 program doesn't help).
Old Aug 28, 2003 | 08:02 PM
91tegrals's Avatar
well in that case man trailer the car..
Old Aug 28, 2003 | 09:16 PM
BlkSIvic's Avatar
200 miles at no higher than 3000rpms
I'd tow it
Old Aug 29, 2003 | 03:45 AM
Patch's Avatar
Default Re: (BlkSIvic)
I change my vote, if its not running correctly and you can get a friend to tow it for gas money and Wendy's, do that.
Old Aug 29, 2003 | 03:03 PM
MEANB18's Avatar
Alrighty, thanks guys
Old Aug 29, 2003 | 03:22 PM
pythonScott's Avatar
Default Re: (MEANB18)
When you get to tuning the engine I doubt that you'll need to purchase larger injectors... the stock injectors already run too rich
Old Sep 1, 2003 | 06:50 AM
powerfulperformance's Avatar
Default Re: (pythonScott)
Well i was in you shoes at one time. I drove around with toda c's, stock injectors, a 12.1 compression bottom end and a ls computer. I did it for around a month before i got my s200 tuned. I just didn't do anything stupid like passing 3k and driving hard. If i were you also, i would get toda valve springs...
Old Sep 1, 2003 | 06:06 PM
MEANB18's Avatar
Default Re: (powerfulperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance &raquo;</TD></TR><TR><TD CLASS="quote">Well i was in you shoes at one time. I drove around with toda c's, stock injectors, a 12.1 compression bottom end and a ls computer. I did it for around a month before i got my s200 tuned. I just didn't do anything stupid like passing 3k and driving hard. If i were you also, i would get toda valve springs...</TD></TR></TABLE>
Really? I thought a lot of people were saying that the Portflows would do just fine, as long as you didn't rev up a lot higher than about 9k?
I also won't be driving the car very aggressive at all, it's little scary when you know your stuff is untuned, and don't run all that great... Just my luck and something would break.
Old Sep 4, 2003 | 03:23 PM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 &raquo;</TD></TR><TR><TD CLASS="quote">
I also won't be driving the car very aggressive at all, it's little scary when you know your stuff is untuned, and don't run all that great... Just my luck and something would break. </TD></TR></TABLE>yes you should have toda springs for spec c's as well as the toda timing belt.
Old Sep 4, 2003 | 03:31 PM
MEANB18's Avatar
Default Re: (EF9_SiR)
nice... anyone wanna trade Toda springs for Portflows???
dwayneblanks
18
Jan 19, 2012 11:43 PM
CPR
Dec 21, 2004 11:02 AM
len
Feb 21, 2004 05:58 PM
95gsr
Jul 30, 2003 06:53 PM
powerfulperformance
Mar 17, 2002 01:40 AM
