Tranny wont come off... help!!!11
Old Aug 28, 2003 | 05:24 PM
Rpc07's Avatar
Default Tranny wont come off... help!!!11
I just installed my new motor and everything but there was something wrong with the clutch and my car wouldnt go into gear... i am pretty sure its the throw out bearing so i am taking the tranny back off to check out everything..
Well i have everything off the tranny that needs to be... all the bolts are undone and there is nothign holding the tranny in place or up... but i cant get the damn thing to seperate from the block.. i have tired to pry the hell out of it... shake it... everything... it is like stuck to the block and i dont know why...
does anyone have any ideas or anything that can help me get this damn tranny off.
thanks
Ryan
Old Aug 28, 2003 | 05:30 PM
JV's Avatar
JV
Who?
Default Re: Tranny wont come off... help!!!11 (Rpc07)
All i have to say is:
Check to make sure every bolt is out... then check again. Some of those bastards like to hide from you. Trust me...
Old Aug 28, 2003 | 05:33 PM
Audi RS4's Avatar
Lover
questions?
1. are the axles removed? (sound stupid and not insulting your technical skills, but we do tend to forget **** sometimes)
2. are all these components removed? or do you notice anything here that you might not have removed yet?
3. is it a hydro or cable tranny?
Old Aug 28, 2003 | 05:37 PM
Rpc07's Avatar
Default Re: Tranny wont come off... help!!!11 (AK1200)
all the bolts are off because there is a gap between the tranny and the block... but i still dont know what is holding the damn thing on... i think it might be the drive shaft maybe.... (the shaft thats in the middle of the tranny)
yes all the axles are out... also it is a hydro tranny
Old Aug 28, 2003 | 05:40 PM
Audi RS4's Avatar
Lover
when you said you are prying on it, are you binding it somehow or do you have someone to help you evenly pry on it?
Old Aug 28, 2003 | 05:59 PM
civic-4-ges's Avatar
When I had to do an engine swap I ran into a similar problem. I used a small rubber hammer and pounded it out evenly all around, it seperated pretty easy after the initial inch or so
Old Aug 28, 2003 | 06:01 PM
Rpc07's Avatar
Default Re: Tranny wont come off... help!!!11 (civic-4-ges)
yes i am prying it evenly... tegasaurus is over her helping me and we cant get this over....
we tried to pound it with a rubber hammer and that didnt work... we got it to come off a little farther now and it will rotate on the shaft a little but still wont give...
HELP
Drew17th
Mar 11, 2006 10:46 PM
EK FLY
Feb 18, 2005 03:29 PM
Ransom
22
Mar 15, 2004 04:06 AM
Rpc07
Aug 28, 2003 10:10 PM
hotintegranights
Jan 5, 2003 02:13 PM
