Need help identifying this ECU
I am interestedin buying this ECU, the seller says it is a 94-95 INTEGRA GS-R P72 OPD1 ECU wiht a serial number of 37820-P72-A01 813-116700 AM
I am not used to seeing an ECU the connectors extended out of the ECU like that, is that right?
TIA
TIA
that i possibly a conversion harness or adaptor of some sort. Ask him for pics of the barcode so you can see the serial number on it. If you want a OBD1 p72 ECU, Ive got one for sale. Let me know if you are interested.
that is some kind of conversion harness, and get a real picture of the barcode, not just what he tells you. that IS a gsr ecu as long as the serial on the ECU matches what he told you.
for future refrence
http://hondata.com/techecuid.html
for future refrence
here is what the guys said when I asked him about the plugs.
"As far as I know, it is an OBD1. The plugs are stock. They are required in order to wire it up."
yeah....tell him to take a clearer picture of the ecu with the TOP cover off. If its a genuine P72 ecu, it will have a knock sensor (daughter board). For OBD1 ecu's, only DOHC VTEC ecu's have a KS board.
HondaGuy951
Mar 7, 2009 01:34 AM
