where can I find abs codes?
Old Aug 28, 2003 | 05:30 AM
moepeppa's Avatar
Default where can I find abs codes?
other than an owners manual, how can somebody find/decode the abs codes once you've discovered what they are (namely for a 96 accord ex).
There's gotta be a site out there somewhere that's gottem!
Old Aug 28, 2003 | 07:14 AM
Martaigne's Avatar
Default Re: where can I find abs codes? (moepeppa)
This is from my 95 Helms, they should be the same system.
1 0 ABS pump motor over-run
1 2 Pump motor
1 3 High pressure leakage
1 4 Pressure switch
1 8 High pressure system
2 1 Parking brake
3 1 RF pulser
3 2 LF pulser
3 4 RR pulser
3 8 LR pulser
3 12 Different diameter tire
4 1 RF wheel sensor
4 2 LF wheel sensor
4 4 RR wheel sensor
4 8 LR wheel sensor
5 0 Right & left rear wheel lock
5 4 Right rear wheel lock
5 8 left rear wheel lock
6 0 Front and rear fail-safe relay
6 1 Front fail-safe relay
6 4 Rear fail-safe relay
7 1 right front solenoid
7 2 left front solenoid
7 4 rear solenoid
8 1 ABS function
8 2 CPU comparison
8 4 Integrated Circuit
Old Sep 13, 2003 | 08:45 PM
jaader's Avatar
Default Re: where can I find abs codes? (Martaigne)
Thanks, I will give this a shot. I wanted to be certain that I was retrieving the ABS codes. I assume that you just count the flashes of the check engine light?
On the SRS systems I have read that you need to turn the key on then off then back on again to allow the SRS light to flash the proper code.
Do I need to count the flases of the check engine light or do I need ot jump another plug to get the ABS indicator to flash the codes?
Regards
Old Sep 13, 2003 | 09:22 PM
Martaigne's Avatar
Default Re: where can I find abs codes? (jaader)
I think there's a second jumper next to the service connector you can jump but don't quote me on that. I'll check my Helms tomorrow. I know there are three there, one is for the CEL, one is for SRS, and I think the third is ABS. You'd jump the connector, turn the key to ON, and count the flashes... ABS is set up you you'll get the first digit in flashes, a pause, then the second digit in flashes, then a longer pause and repeat.
Old Sep 14, 2003 | 04:28 PM
Dre742's Avatar
I am not to familiah with the way this works but I have a Question for anyon who knows about it,Can a h22 head wok on a f22 block?
Old Sep 15, 2003 | 03:22 PM
Martaigne's Avatar
Default Re: (Dre742)
No, and what's that have to do with ABS???
jdm201010
Apr 18, 2014 12:08 PM
tapwc19
May 31, 2009 06:01 PM
srlance24
Apr 23, 2008 10:52 AM
JimBlake
Nov 23, 2005 04:58 AM
meat
Aug 5, 2003 11:41 AM
