CEL Issues.... No code though.
Old Aug 27, 2003 | 07:30 PM
ShagginJet's Avatar
Default CEL Issues.... No code though.
This is a redirect, sorry but I really need some help.
https://honda-tech.com/zerothread?id=599292
Old Aug 27, 2003 | 07:32 PM
mmuller's Avatar
Mad Scientist
Default Re: CEL Issues.... No code though. (ShagginJet)
have you tried swapping ecu's?
Old Aug 27, 2003 | 08:14 PM
ShagginJet's Avatar
I've thought about it but haven't bothered to look into it. You seriously think that could be the problem?
Old Aug 28, 2003 | 04:16 AM
JimBlake's Avatar
Default Re: (ShagginJet)
Ignition switches have also been known to get flakey. Can you make it happen if you wiggle the key while it's running? I'd check around with a DMM to make sure the switch and all the wiring was OK. Unless you just happen to have a spare ECM...
Old Aug 28, 2003 | 07:52 AM
1bad-eg's Avatar
Default Re: (JimBlake)
I agree with JimBlake...when an ignition switch starts to act up all sorts of lights can turn on. Like the cel, srs, abs, etc.
Tyler Cloutier
Sep 7, 2024 05:13 PM
Civic94cx
Sep 22, 2010 04:19 PM
Chris F
Nov 2, 2009 02:40 PM
borg_jos
10
Jul 14, 2009 12:52 PM
