!Need help with smoking engine!
Old Aug 27, 2003 | 06:04 PM
gregcivic92lx's Avatar
New User
Default !Need help with smoking engine!
I have a 1992 LX with a D15B7. I've always had a problem with excessive oil consumption and smoking. I recently changed the valve seals and it smokes worse than before. I did a compression check and all cylinders are around 145-150. So it seems I have good compression, but yet it still smokes and burns oil. Does anyone have any ideas of what could be causing this problem?
Old Aug 27, 2003 | 08:03 PM
Fkned2003's Avatar
Default Re: !Need help with smoking engine! (gregcivic89dx)
Did you or a shop install the seals?Poss they weren't put on right .Do a leakdown to see if rings are bad.
Old Aug 28, 2003 | 09:49 AM
New User
Default Re: !Need help with smoking engine! (Fkned2003)
i installed the seals while the head was out of the car, i double checked all the seals b4 i installed it again i did this all in my friends shop , he helped me out with the install , as far as a leakdown test , what does that involve???
Old Aug 28, 2003 | 03:40 PM
Fkned2003's Avatar
A leakdown goes like this,remove plugand put the cyl you are testing at tdc compression,then you screw fitting into the plug threads and fill with compressed air.then you read the gagues to see how much leakage there is in the cyl.0-5%is good and up to 10%on a street car is acceptable,race no more than 2-4%.If the leak is coming from the dipstick the rings are bad,exhaust or intake manifold leaks mean bent valves or bad valve job.Any competant mechanic shop should be able to perform this for you.
Old Sep 1, 2003 | 08:25 AM
New User
Thanks man i'm gonna try that, if that not the problem i'm just gonna swap a a6 head on it , and see what happens
G3teg96
14
Aug 11, 2011 10:23 AM
parkerjamison
Sep 11, 2008 07:32 PM
red teg
Oct 9, 2005 03:33 PM
bundy
Nov 19, 2002 09:04 PM
