Anyone with autometer fuel pressure gauge in car??
Ok i have an autometer fuel gauge, with isolator so it can be mounted inside the car. my question is where should i tap into the fuel line at?? I have to hook up a 4an line to the isolator and gauge. anyone done this? thanks.
Above the fuel filter is a good spot.
You must have the correct bolt for this though. The fuel filter is the can that is at a 115 degree angle on the firewall next to the battery.
C-Speed Racing has a good how-to.
I have the mechanical gauge. all that came was the gauge and a 90° fitting to go on the back of the gauge. My kit didnt come with a setup like yours does right on the filter. That looks like the setup for the electrical gauge??
Strng1dah:
Are you using the orange air compressor hose for an Oil Catch Can?
How does it hold up to engine temps?
If not, what are you using it for?
Thanks,
Karl
Thanks,
Karl
You can mount the mechanical gauge inside the car with use of a fuel isolator. it sends a water/coolant mixture instead of fuel inside the car. I have this, and it takes a 4an line. I just need somewhere to hook the 4an line into the fuel system somewhere..
I showed how to make a custom eletric one here: https://honda-tech.com/zerothread?id=61770
pics/instructions in the link above, -C
Thanks...I think i'm just gonna drill into the bolt like you did, and put a 90° 4an fitting on the end of it. that was a good idea.
canuck-mx6
Jun 27, 2002 12:13 PM
