good idea or not?
My friend has an ITR exhaust cam laying around and I was wondering if it was worth putting in on a 1st gen b16 without changing the springs or anything for now? Will it be safe and will it make a difference at all or should I save me trouble of taking off the stock one and stuff?
Thanks
Thanks
I am assuming that the ITR cams are taller then what you putting in..
and your now more likely to float a valve then before, so you may want to watch how high you rev your motor, if you take it into the red on a regular basis..
