99-00Si vs 94-01GSR brake sizes
Old Aug 27, 2003 | 03:12 PM
STEALTHMODECOUPE's Avatar
Default 99-00Si vs 94-01GSR brake sizes
just wondering what are the difference in the brake sizes front and rear..thanks
adaM
Old Aug 27, 2003 | 06:15 PM
Mohudsolo's Avatar
Default Re: 99-00Si vs 94-01GSR brake sizes (STEALTHMODECOUPE)
So far as I know, they are the same exact brakes, same as the mid 90's ex civic.
Old Aug 28, 2003 | 03:35 PM
Default Re: 99-00Si vs 94-01GSR brake sizes (Mohudsolo)
really..hmm can anyone else verify this??
adaM
Old Aug 28, 2003 | 04:09 PM
NonovUrbizniz's Avatar
Loved
they're the same.
Old Aug 28, 2003 | 04:38 PM
JDMHN8's Avatar
Default Re: 99-00Si vs 94-01GSR brake sizes (NonovUrbizniz)
Both use 262mm rotors and the same caliper...
Old Aug 29, 2003 | 05:29 AM
Default Re: 99-00Si vs 94-01GSR brake sizes (JDMDA9)
ok thanks guys..i guess my other question would be then if i wanted to upgrade to 96 spec ITR rims would i have to get the brake conversion also cause of the slightly different bolt pattern and if so are the ITR brakes even any better cause i heard there the same size as the gsr's and Si's..
adaM
Old Aug 29, 2003 | 05:43 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
I assume you mean 97 Type R. You must swap the whole hub and caliper. Type R brakes are 5 bolt to your 4. More than a "slight difference" Type R brakes are 11.1 inch.
Old Aug 29, 2003 | 06:06 AM
Default Re: 99-00Si vs 94-01GSR brake sizes (madhatter)
no i meant the 96 ITR brake conversion
adaM
Old Aug 29, 2003 | 09:37 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE &raquo;</TD></TR><TR><TD CLASS="quote">no i meant the 96 ITR brake conversion
adaM</TD></TR></TABLE>
You must be referring to the 4x114 conversion, correct?
..if so, then yes you will still have to change your front knuckle/hub assembly to that of a 95-97 JDM ITR knuckle/hub assembly (plus rear trailing arms too) along with 95-97 ITR wheels.
Btw, the brake size of the 4x114 is exactly the same size as all 94-00 integra brakes btw, 10.4". They're not 11" rotor's with bigger piston calipers like all 5-lug ITR/CTR brakes.
Old Aug 29, 2003 | 11:49 AM
Default Re: 99-00Si vs 94-01GSR brake sizes (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
yup thats what im refering to and thanks katman those are the answers i was looking for
adaM
Old Aug 31, 2003 | 12:37 PM
Katman's Avatar
np
no1else
Honda CR-V & Element
Jun 23, 2013 03:32 PM
Mr.E.G.
Oct 30, 2008 09:35 PM
CustomEJ6
10
Apr 18, 2007 11:51 PM
gsrhb7
Northwest (Sales)
24
Apr 19, 2006 01:03 PM
remo
Jan 13, 2005 03:45 PM
