spark problem
Old Aug 27, 2003 | 01:49 PM
dinkydx's Avatar
Default spark problem
i just put a d16z6 into my 92 cx
i am getting no spark
i changed the distributor coil with the msd setup
i hooked everthing up rechecked over and over again still i get no spark
any suggestions?
thank you
Old Aug 27, 2003 | 04:31 PM
MrHeeltoe's Avatar
Default Re: spark problem (civicprelude)
Check the wire that goes from the igniter unit to the coil. That wire is a signal wire for the coil to spark. If you put a test light on there while you are cranking the motor, it should blink, as though the motor is firing. Of course, you will need to remove the distributor cap to do this test, but if you get no blinking, you need a new igniter. About $100-$120 at the dealer....
Old Sep 1, 2003 | 05:56 AM
dinkydx's Avatar
Default Re: spark problem (MrHeeltoe)
im getting juice to the distributor
im not getting any spark still and no fuel from the pump, it doesnt turn on
im confussed?
Old Sep 1, 2003 | 06:20 AM
mmuller's Avatar
Mad Scientist
it could be your main relay
jakescakesz06
Jan 4, 2016 09:38 AM
cody1234
Nov 30, 2012 05:34 AM
bumbek
Jul 16, 2008 07:03 PM
crxY-49
Sep 10, 2003 12:23 PM
