excessive engine vibration pulling through 3rd and 4th gear
Old Aug 27, 2003 | 01:17 PM
5 Skware's Avatar
I missed the boat
Default excessive engine vibration pulling through 3rd and 4th gear
Hey guys need a little help here, I got done installing a B16A2 into my EK hatch and it is doing great except for a bad engine shake. It is most noticable pulling hard through third and fourth gear, and is worst going through the 40-50 mph area. I have checked and double checked the motor mounts and they seem fine so now I am stumped.
Possible ideas that I had:
#1- Axles- not sure if this can cause a shake but the passenger axle was really hard to install?
#2- little torque mount for AC- the rubber is a bit torn but it was the same on the EG I got the motor out of and it had no shake?
Any help is greatly appreciated, I need to get this taken care of it feels like the motor is gonna rip out of the car
Old Aug 27, 2003 | 02:06 PM
Spade's Avatar
Default Re: excessive engine vibration pulling through 3rd and 4th gear (EGCIV)
Wheel lugnuts.
Wheel balancing
Axles tweaked.
Check all of above.
Old Aug 27, 2003 | 02:21 PM
5 Skware's Avatar
I missed the boat
Default Re: excessive engine vibration pulling through 3rd and 4th gear (Spade)
Lug nuts- torqued to spec
Wheels - rebalanced recently (thought that could be the prob also)
Axles tweaked- Not sure how to check? Just look at them or is there a way to test them?
Thanks for the suggestions
Old Aug 27, 2003 | 03:46 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">Wheel lugnuts.
Wheel balancing
Axles tweaked.
Check all of above.</TD></TR></TABLE>
all are fine.
https://honda-tech.com/zerothread?id=603464
I already made a post last night Jon
this is so stupid
Old Aug 28, 2003 | 05:13 PM
5 Skware's Avatar
I missed the boat
Default Re: excessive engine vibration pulling through 3rd and 4th gear (Emerika)
A little more info here maybe it will help :
Everything worked perfectly in the EG that the motor was pulled from.
All the mounts are nice and tight.
I just removed bnoth axles and reinstalled them.
Still has the same shake! I am willing to try anything just need some more suggestions please.......
gsr96cx
Dec 13, 2008 02:28 PM
HUBB
Mar 25, 2004 05:17 PM
ID_ten_T
Jan 12, 2004 07:08 PM
5 Skware
Aug 28, 2003 06:48 PM
5 Skware
Aug 28, 2003 05:12 PM
