Mini me question
Old Aug 27, 2003 | 10:44 AM
CRX Si's Avatar
Default Mini me question
Hey guys, I posted this in the Tech forum too but thought you guys might be able to help as well... Anyway, I did some searching about mini-mes and a lot of people say that it is a PITA to use my D16A6 Dizzy with a Z6 head... Can someone break it down for me and tell me what exactly is involved in using this Dizzy/Head combo...
TIA,
JAson
Old Aug 27, 2003 | 10:53 AM
Vinceg99's Avatar
Default Re: Mini me question (CRX Si)
Im not sure which one your suppose to cut off exactly but in order for the A6 dizzy to mount onto the Z6 head you have to cut one of the legs off in order for it to mate right...Do you have the Z6 head already? Cause if not if you happen to pick up a Y8 head for the mini-me the A6 dizzy bolts right up to that head but there have been people that say that the Y8 head doesnt flow as well as the Z6 head though.
Old Aug 27, 2003 | 11:01 AM
USDM 4G VTEC's Avatar
well to make it fit u have too cut the bottom front leg...... ill show u a pic to show u.... if u pay attention u can tell how u cutted the front leg in order to make it fit..... the top one deosnt need to be cut.. the bolt will be out of the leg.... and u can just use a washer to hold it on place
Old Aug 27, 2003 | 11:40 AM
CRX Si's Avatar
Default Re: Mini me question (USDM 4G VTEC)
thanks guys, and I didnt get the head yet But i got a good deal in the works for a Z6... What are my other options when it comes to different dizzys?
Old Aug 27, 2003 | 12:32 PM
photonjedi808's Avatar
if you switch to a P28 you can use the Z6 dist
other than that you have no other options
I used a long skinny bolt with a couple of washers and a nut to hold on the dist. Holds tight and still allows for adjustment
Old Aug 27, 2003 | 12:42 PM
The Brown Kid's Avatar
Default Re: Mini me question (photonjedi808)
I used the crx stock dizzy ad ihad to dremmel out the inside until it fit. I dont have anypics but ill look for one
Old Aug 28, 2003 | 05:22 AM
CRX Si's Avatar
Default Re: Mini me question (The Brown Kid)
and since I will be using the crx ECU what is the best way to run the Vtec
Old Aug 28, 2003 | 06:00 AM
davens's Avatar
http://crx.honda-perf.org/arti....html
Try that...it might answer some basic questions
Old Aug 28, 2003 | 06:12 PM
CRX Si's Avatar
Default Re: Mini me question (davens)
muchos gracias
Old Aug 28, 2003 | 06:24 PM
Lightning Lover.'s Avatar
interesting, the pic helps alot
Old Aug 28, 2003 | 06:42 PM
Redline130's Avatar
Default Re: (Dr. Physics)
Here is how I mounted a A6 dizzy to a Z6 head. It's not pretty, and probably not the best way, but the car starts and runs.
http://www.angelfire.com/dc2/c....html
SPOON_BeIgHtEeNsEe
May 1, 2008 12:46 PM
Red_ED8
Dec 6, 2007 11:22 AM
Civic98KH
May 16, 2007 09:16 AM
Lightweight Boost
Jan 1, 2007 01:19 PM
4doorcivic16
May 8, 2006 06:35 AM
