Spoon Final Gear Set??
Old Aug 15, 2001 | 08:41 PM
N1Spec's Avatar
New User
Default Spoon Final Gear Set??
anyone here have the Spoon final gear set of 4.875?
can someone please confirm what the final drive ratio is on 1.) JDM ITR and 2.) USDM ITR??
Old Aug 15, 2001 | 08:43 PM
Reid's Avatar
Global Moderator
Default Re: Spoon Final Gear Set?? (N1 Spec)
JDM - 4.785
USDM - 4.400
Old Aug 15, 2001 | 09:46 PM
AJ PwR's Avatar
I used to have it . It was a very good ratio for street or track.
Old Aug 15, 2001 | 10:03 PM
N1Spec's Avatar
New User
Default Re: Spoon Final Gear Set?? (AJ PwR)
is the diference in acceleration noticable?? ta
Old Aug 15, 2001 | 10:14 PM
AJ PwR's Avatar
Definitely!!!! Cos I do a lot of track days so I give up the FD and I got Cross gears now.
Old Aug 15, 2001 | 11:04 PM
Saga's Avatar
just a little clarificaton the spoon FD is 4.862 for 98specR
Old Aug 15, 2001 | 11:19 PM
Mugen_R's Avatar
New User
I've heard of cross gears before, what isit?
Old Aug 16, 2001 | 12:21 AM
RagingAngel's Avatar
Default Re: Spoon Final Gear Set?? (Mugen_R)
I'm not sure where the name comes from..
but it is essentially the custom selection of gears to your desired spec...
the range is limited to a few choices...or else the price will be even more exorbitant than it already is to the mere mortal enthusiasts such as myself.....!
as an example.... some people like a shorter 2nd and 3rd gear...but would like to maintain the other gear ratios.... this cannot be accomplished with changing the final drive as it affects all the gears....
Ofcourse...if I'm mistaken ....somebody out there .....beat my statement down and prove I'm wrong...!
Old Aug 16, 2001 | 12:38 AM
N1Spec's Avatar
New User
Default Re: Spoon Final Gear Set?? (RagingAngel)
your about right there RagingAngel, i think they are known in japan as "cross mission"
anyone know if the ones offered by Spoon are straight cut gears? i would imagine they are great for circuit.
[Modified by N1 Spec, 9:40 AM 8/16/2001]
Old Aug 16, 2001 | 01:26 AM
JDM_DOHC_SiR's Avatar
New User
HAhaha Over here in Japan if you were to here a Japanese perdon say "CLOSE" or "CROSS" it sounds the same but what they really mean is Close.. I have brought up this point to my friend that works at Type-One (Spoons new retail store)...Also the gears are cut the same as factory gears..
Old Aug 16, 2001 | 02:21 AM
Saga's Avatar
Default Re: Spoon Final Gear Set?? (JDM_DOHC_SiR)
close mission...I never thought of that
AJ PwR
Dec 15, 2003 07:22 PM
Chris N
Nov 19, 2002 05:29 PM
Pelican
Aug 3, 2002 12:53 PM
norice
May 3, 2002 05:15 PM
