Spoon Final Gear Set??
anyone here have the Spoon final gear set of 4.875?
can someone please confirm what the final drive ratio is on 1.) JDM ITR and 2.) USDM ITR?? |
Re: Spoon Final Gear Set?? (N1 Spec)
JDM - 4.785
USDM - 4.400 |
I used to have it . It was a very good ratio for street or track.
Re: Spoon Final Gear Set?? (AJ PwR)
is the diference in acceleration noticable?? ta
Definitely!!!! Cos I do a lot of track days so I give up the FD and I got Cross gears now.
just a little clarificaton the spoon FD is 4.862 for 98specR
I've heard of cross gears before, what isit?
Re: Spoon Final Gear Set?? (Mugen_R)
I've heard of cross gears before, what isit? but it is essentially the custom selection of gears to your desired spec... the range is limited to a few choices...or else the price will be even more exorbitant than it already is to the mere mortal enthusiasts such as myself.....! as an example.... some people like a shorter 2nd and 3rd gear...but would like to maintain the other gear ratios.... this cannot be accomplished with changing the final drive as it affects all the gears.... Ofcourse...if I'm mistaken ....somebody out there .....beat my statement down and prove I'm wrong...! http://images.zeroforum.com/smile/emsmilep.gif |
Re: Spoon Final Gear Set?? (RagingAngel)
your about right there RagingAngel, i think they are known in japan as "cross mission"
anyone know if the ones offered by Spoon are straight cut gears? http://images.zeroforum.com/smile/emhammer.gif http://images.zeroforum.com/smile/emsmilep.gif i would imagine they are great for circuit. http://images.zeroforum.com/smile/emsmilep.gif [Modified by N1 Spec, 9:40 AM 8/16/2001] |
HAhaha http://images.zeroforum.com/smile/emsmilep.gif Over here in Japan if you were to here a Japanese perdon say "CLOSE" or "CROSS" it sounds the same http://images.zeroforum.com/smile/emwink.gif but what they really mean is Close.. http://images.zeroforum.com/smile/emwink.gif I have brought up this point to my friend that works at Type-One (Spoons new retail store)...Also the gears are cut the same as factory gears..
Re: Spoon Final Gear Set?? (JDM_DOHC_SiR)
