Major problem after converting automatic to manual
Old Aug 27, 2003 | 08:50 AM
mz3bo's Avatar
Default Major problem after converting automatic to manual
Hello, i had everything done properly to convert an automatic integra (96) to manual. However, when I put the key to iginition, the check engine light does no light on and I don't hear any fuel pump pumping. There is only a few light that goes on in the dash, but the oil, battery, check engine and SRS does not. What is worst, all the fuses are ok, and when I put the automatic ecu back in, there is still no light... looks like somethings wrong. I even had the automatic shifter console plug in but there is still no light in the dash.
Can someone help a me out.. i am going nuts...
Cheers
Bo
Old Aug 27, 2003 | 09:00 AM
Trooper's Avatar
Default Re: Major problem after converting automatic to manual (mz3bo)
plug the automatic shifter console back in and make shure that the selector is in park.
Old Aug 27, 2003 | 09:02 AM
mz3bo's Avatar
Default Re: Major problem after converting automatic to manual (Trooper)
That is done... but there is still no light in the dash... it looks like when you put to ingnition without having an ecu plugged...
Old Aug 27, 2003 | 11:35 PM
4DeepCivic's Avatar
Just to ask. Did you change your ecu?
ecookjr71
Honda CR-V & Element
Feb 26, 2011 03:32 PM
h22honda89
10
Aug 19, 2007 02:40 PM
blackludevtec
Apr 4, 2007 02:21 PM
ukmastermind
Sep 28, 2005 05:58 AM
86CRXSi
Jun 3, 2002 05:06 PM
