which one would be a better swap? the b20 or the h22?
Old Aug 26, 2003 | 11:46 PM
teamblurrycl's Avatar
Default which one would be a better swap? the b20 or the h22?
i have a 97 acura 2.2cl. basicly it's an accord in a nicer body. i was thinking about doing a swap. i'm currently deciding between the h22 and the b20.
b20- was used for the crv and the 98-91 prelude. every civic i know that has this swap just and mounds of un-useable torque. they just spin their tires for days before they get any traction. i was thinking "may-be, since my car is heavier, i might be able to use some of the torque." plus if it was able to move a suv, i think it could move my car.
h22- it's a more common swap and might cost me less. i could use my existing tranny and just replace the axles.
so which swap should i do?
Old Aug 27, 2003 | 08:20 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: which one would be a better swap? the b20 or the h22? (teamblurrycl)
The B20 in the preludes and the B20 that "every civic is running around with" are COMPLETLEY differn't motors. Good luck getting one of those into a CL with out someone building you custom mounts. As far as the H22 motor as long as the CL has the same mounting style as the Accord/Prelude you shoudl be fine. For somereason I don't think they are because I've never seen a swaped CL or heard about it before. Don't get me wrong I've seen plenty of modded ones, just most of em just bolt-on's and nitrous or the occasional S/C and once in a blue moon custom turbo. You'd probably have more luck in Tech or Hybrid.
Old Aug 27, 2003 | 08:34 AM
it's a f22b1. so the h22 would fit perfectly
Old Aug 27, 2003 | 08:36 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (teamblurrycl)
Well then H22/H23 and other F-Series are going to be the only direct swaps.
Old Aug 27, 2003 | 10:18 AM
AllMoToRB18c's Avatar
Default Re: (Mr Milano)
just becuz its a f series motor doesnt mean its the same fseries as the accord....91 preludes are b series but theyre not the same b series as gsr and crv's so it might not work ...i would do more research on that b4 i try it...that sounds like a serious job to me...but maybe im wrong
Old Aug 27, 2003 | 10:58 PM
Default Re: (AllMoToRB18c)
isn't the 91 prelude b20 just a b20 block with a non v-tec head?
Old Aug 27, 2003 | 11:34 PM
CD8's Avatar
CD8
actually the cl 96-97 cls use the same exact mounts as the accord... hence the h/f motors drop in and yes its the same motor as accords.
Old Aug 28, 2003 | 09:12 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamblurrycl &raquo;</TD></TR><TR><TD CLASS="quote">isn't the 91 prelude b20 just a b20 block with a non v-tec head?</TD></TR></TABLE>
Absolutley not. And all B20's are non VTEC.
Old Aug 28, 2003 | 11:25 AM
B3AS's Avatar
h22 is better motor. easier to swap into your application.
Old Aug 28, 2003 | 08:25 PM
Rukusmasta2's Avatar
Default Re: which one would be a better swap? the b20 or the h22? (Love2race)
i have 94 accord ex and my boy got a 97 cl 2.2 same exact motor f22b1 so it should be da same as puttin h22 into accord...H22 gets my pick
Old Aug 31, 2003 | 10:50 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamblurrycl &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 acura 2.2cl. basicly it's an accord in a nicer body. i was thinking about doing a swap. i'm currently deciding between the h22 and the b20.
so which swap should i do?</TD></TR></TABLE>
You are never getting a b20 in that car without spending a lot of $$$$
As said earlier the h22 is a better choice for your car and has more torque than a b20.
bdolan2121
Jul 16, 2012 12:39 AM
rick_rabies
Apr 24, 2009 10:54 AM
pelotudo
Oct 18, 2002 11:01 PM
89B16HBSBETTERHALF
Sep 4, 2002 02:39 AM
lstec2b
May 15, 2002 01:57 PM
