i cut down my shifter today
Old Aug 26, 2003 | 10:15 PM
integra dave's Avatar
Default i cut down my shifter today
the car: 5th gen accord wagon lx
long story short..... i have a neuspeed short short shift adapter in the car now > about a 30 percent shorter throw than stock...... i decided to shorten it more by cutting down the stick..... it worked!!!! i took about 1.5 inches off >> basically enough to leave room for the momo shift **** about 1 inch above the 1st curve from the top >
if you have not done it, do it > now the throw feels like a 40 percent shorted throw
Old Aug 26, 2003 | 10:39 PM
im_the_teacher's Avatar
Default Re: i cut down my shifter today (integra dave)
i've done it.....i cut my stock shifter shaft down to two inches. using the dye grinder and rethread the shaft.....is feel way better than original height....
make sure u wear a good safety google when do this mod.....i heard someone got spark fly into their eyes......(long story) but he recover.
Old Aug 26, 2003 | 11:28 PM
CD8's Avatar
CD8
Default Re: i cut down my shifter today (im_the_teacher)
i like my 4bidden TRUE short shifter
Old Aug 26, 2003 | 11:35 PM
whoa its len 2's Avatar
Default Re: i cut down my shifter today (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">i like my 4bidden TRUE short shifter </TD></TR></TABLE>
gotta pic of it?
anybody got a pic of the pspec one too? theyre both the whole lever right?
Old Aug 27, 2003 | 12:34 AM
david90's Avatar
Can u just do a homemade short shifter by cutting the stock one shorter?
Old Aug 27, 2003 | 12:38 AM
jjj784's Avatar
Default Re: i cut down my shifter today (whoaitslen2)
len!!! you haven't seen my shifter? it's the pspec one. lols!
Old Aug 27, 2003 | 02:33 AM
Default Re: i cut down my shifter today (jjj784)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjj784 &raquo;</TD></TR><TR><TD CLASS="quote">len!!! you haven't seen my shifter? it's the pspec one. lols! </TD></TR></TABLE>
really.. i dont remember.. next meet
Old Aug 27, 2003 | 06:41 AM
TypeSH's Avatar
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">Can u just do a homemade short shifter by cutting the stock one shorter?
sort of, its not the same.
Your shifting distance is determined by the amount of throw the cables have, and the amount of travel your moves (determined by length of lever)
if you raise the shifter cables via an adapter, or a replacement short shift lever (PSPEC/4bidden/C's), you shorten the throw/movement of the cables. In turn, the amount of movement your lever is shortened.
if you only shorten the stick/lever, the amount of movement your hand moves is less, but it requires more force to push the lever now, and the movement/throw of the cables is not changed.
if you do both, you generally end up w/ a much less hand movement required, but one taht still does require more force to move.
Old Aug 27, 2003 | 08:13 AM
CD8's Avatar
CD8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">
gotta pic of it?
anybody got a pic of the pspec one too? theyre both the whole lever right?</TD></TR></TABLE>SEARCH its been around for a while now...
Tiger_Si
Aug 15, 2008 12:47 PM
ProjectCD5
Feb 21, 2006 11:55 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
almightyaccord
Feb 15, 2003 07:21 PM
Ekco
Jun 13, 2002 12:36 PM
