wut all will i need to do with the b18a????? help asap please
ok i have a 93 b18a and i think it is obd 0 but im not sure is it obd0 or obd1 and if it is obd 0 wut all will have have to convert to make it obd1 for my 93cx hatch
Hasport undoubtedly sells a sub harness for this. I'm not going to adress engine mounts, axles, shift-linkages, cable/hydro tranny, etc.
I would use the original engine harness that the car came with.
ecu conversion harness OBD0-OBD1
remove resistor box
re-pin injectors
re-pin distributor
run 4-wire O2 sensor
lengthen/shorten various connectors.
What I did was put the two engine harnesses side by side, and made ONE good one.
I have the beginnings of a writeup for this, I'll try and finish it up.
-PHiZ
remove resistor box
re-pin injectors
re-pin distributor
-PHiZ
bobbyisking
Jul 7, 2008 09:22 AM
mahatma
Jun 4, 2006 07:30 AM
KiNG $h!t
Jun 27, 2004 06:10 PM
lococoin
May 21, 2004 03:42 AM
