Integras with full race or tubular manifolds..radiators?
Old Aug 26, 2003 | 12:04 PM
NyQuiL's Avatar
Default Integras with full race or tubular manifolds..radiators?
what style radiator are you guys using?, have you converted to the civic rad's?
i was thinking about this because the full race style mani pokes the wastegate out dosent it?, wouldnt that shove into the radiator?
Old Aug 26, 2003 | 12:13 PM
legendboy's Avatar
Default Re: Integras with full race or tubular manifolds..radiators? (NyQuiL)
yes you need to use a different rad
Old Aug 26, 2003 | 12:21 PM
NyQuiL's Avatar
ok... anyone know what kind?!? im guessing the only smaller replacement would be switching to the sohc rad, correct?
Old Aug 26, 2003 | 02:24 PM
PM-Performance's Avatar
Default Re: (NyQuiL)
im working on the same thing as we speak , i just ordered my tinker manifold today . you will need to use a single legnth, i will prob go with fluidyne or PWR , just not sure how mounting will work?
Old Aug 26, 2003 | 02:42 PM
01ITR#700's Avatar
Default Re: (itr206)
I'm running a Civic Radiator. It's an "aftermarket heavy duty" one from Checker I believe. It's a bit thicker then the stock Civic Radiators. It fits pretty damn good, just fabbed a single simple bracket and it looks pretty stcok
Mark
Old Aug 26, 2003 | 03:08 PM
NyQuiL's Avatar
01ITR#700 please post some pics up
i ordered a tink manifold to, i guess im gona be converting to the civic radiator as well, gona try to get either a pwr or c&r
Old Aug 26, 2003 | 03:20 PM
SuperTeg95's Avatar
Im using a civic Fluidyne radiator. There is alot more room with the smaller radiator there.
Old Aug 26, 2003 | 09:52 PM
NyQuiL's Avatar
is it cooling everything ok?, im taking it both of you guys dont have ac.
Old Aug 27, 2003 | 07:14 AM
spike's Avatar
where's a decnt priced radiator? I'm going turbo DA myself and am looking into the same thing.. main prob I see is the crossmember.
Old Aug 27, 2003 | 07:16 AM
GRTechnologies's Avatar
Default Re: (spike)
there is a stock 2 core you can get form you local parts store from an automatic 94 civic or just buy a c&r!
Old Aug 27, 2003 | 07:36 AM
spike's Avatar
Default Re: (GR)
and it will fit right in? The CRX we just did .. we purchased a stock radiator from a del sol and thought it would fit in.. but unfortunately it was too high.. didn't want to run into the same prob.
Old Aug 27, 2003 | 11:08 AM
legendboy's Avatar
Default Re: (spike)
I've never had a problem with boost and a civic half rad. Not exactly bling but it works fine. You don't need a 2 pass rad or anything imo.
Varano44
Sep 17, 2008 05:13 AM
DA is best
Jan 8, 2007 08:24 PM
DS002
Jun 16, 2006 01:17 PM
yee SERIOUS
May 19, 2005 09:55 PM
