NEED HELP WITH SPEEDOMETER (VTEC NOT WORKING)
Old Aug 26, 2003 | 11:28 AM
civic99sohcvtec2's Avatar
Default NEED HELP WITH SPEEDOMETER (VTEC NOT WORKING)need expert advice!!!
MY SPEEDOMETER IS NOT WORKING IT WENT ON AND OFF FOR A HILE JUMPING THEN IT DONT WORK. IVE CHANGED THE VSS AND THE GAUGE CLUSTER STILL NOTHING? IVE FOLLOWED THE WIRE FROM THE VSS TO CLUSTER THEN TO THE ECU STILL NOTHING EVERYTHING SEEMD FINE. RAN OUT OF THING TO DO KNOW VTEC DONT WORK MY FUEL INJECTOR DURATION IS MESSED UP AND ITS ******* WITH A BUNCH OF **** MAKING IT RUN WEIRD ANYONE HAVE A PROBLOM LIKE THIS BEFORE??? IF SO PLEASE STATE SOLOUTION OR HELL ANY IDEAS PLEASE STATE THEM!!! THANKS
Modified by civic99sohcvtec2 at 10:34 PM 8/26/2003
Old Aug 26, 2003 | 12:03 PM
tour de france turbo's Avatar
Default Re: NEED HELP WITH SPEEDOMETER (civic99sohcvtec2)
what kind of engine are you running? ECU?
Old Aug 26, 2003 | 12:16 PM
Default Re: NEED HELP WITH SPEEDOMETER (stock ek sleeper)
i have a d16y8 engine with the stock obd2 ecu
Old Aug 26, 2003 | 12:18 PM
realblag's Avatar
caps=yelling
bad grammer and no punctuation=no reply
try again=decent help
Old Aug 26, 2003 | 02:35 PM
u2civic1's Avatar
Default Re: NEED HELP WITH SPEEDOMETER (realblag)
vtec need the car to be a certain speed for it to activate as well as rpm. since your not get the vss singnal vtec is not working
check to see if your plug for the vss is dirty or bad that was my problem
Old Aug 26, 2003 | 04:25 PM
eg6h8k's Avatar
Default Re: NEED HELP WITH SPEEDOMETER (u2civic1)
heres a though...since u replace the vss already...asumming theres nothing wrong w. the vss...take it out reach ur hand in the small hole..see if u could feel where the shaft of the speed sensor meets up..its should be a 3 groove cut..big *** ring that goes around the differential..when they meet it spins the vss and thats how ur car get its speed...it should be tight no movement what so ever...and recheck everything..again...fuses too..gl
Old Aug 26, 2003 | 04:26 PM
blackhatchy's Avatar
Default Re: NEED HELP WITH SPEEDOMETER (eg6h8k)
STOP YELLING AT ME!!!!!
Old Aug 27, 2003 | 12:36 PM
ruthless013's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 &raquo;</TD></TR><TR><TD CLASS="quote">check to see if your plug for the vss is dirty or bad that was my problem</TD></TR></TABLE>
patric8332
Jan 23, 2009 02:34 PM
NeRdY
Jul 30, 2006 10:08 PM
hndakd
Nov 16, 2004 03:57 PM
~~~InNeEdFoRsPeEd~~~
Jul 3, 2003 08:40 PM
HT Chaplain
May 3, 2003 08:23 PM
