Brake Light On In Dash While Braking -- Prelude 5 Gen.
Old Aug 26, 2003 | 11:10 AM
autosell2001's Avatar
Default Brake Light On In Dash While Braking -- Prelude 5 Gen.
Hi does anyone know what is the reason for the brake light coming on in the dash while I step on my brakes? I recently had a turbo installed not sure had to do with it. Please help peeps. Thanks!
Old Aug 26, 2003 | 11:12 AM
EsQueue's Avatar
****, check to see if you have enough brake fluid. That sounds like something that you don't want to play with.
Old Aug 26, 2003 | 11:23 AM
Default Re: (SeaQuake)
Yeah I did my brake fluid is ok. I am not sure what is causing to do that. This si irritating me like crazy!!
But weirdest thing is when I drive it for a while the brake light in dash would go off? Does anyone know why would it go off when the car is warm?
Old Aug 26, 2003 | 11:29 AM
EsQueue's Avatar
Does the car have ABS or is it giving you a CEL?
Old Aug 26, 2003 | 11:34 AM
Yes, my lude have ABS. But it is the brake light in dash is the one when you pull your hand brakes up. But when I put my hand brakes down it still lights up.
Old Aug 26, 2003 | 11:40 AM
EsQueue's Avatar
If I am correct that brake light will illuminate when your hand brakes are up and if our fluid is low. I think it also lights to tell you if there is a problem with your brake system too. Someone correct me if I am wrong. If you don't recieve help from here I suggest you get it checked by someone who knows what they are doing.
I try to work on my car but will never try to troubleshoot brake problems.
Old Aug 26, 2003 | 11:43 AM
Thanks for your help SeaQuake. If your statement is true then I am gonna get the brakes check. Last time I checked I had plenty brake pads. Yeah, this is very strange. The reason I dont want to take it to a dealer they may say it has to do with my turbo setup?? That is why I am also wondering can that be the problem?
Old Aug 26, 2003 | 02:42 PM
EsQueue's Avatar
bumb, help anyone?
Old Aug 26, 2003 | 04:22 PM
Just had my brake pads checked and seemed to be fine. I did add a little brake fluid since someone did mention that sometimes the fluid gets clogged and it tends to activate the in dash brake light. Let me drive3 it later and see if it still comes on.
nochel
May 26, 2008 08:06 PM
UK PRELUDER
Jan 22, 2006 09:15 AM
vietJDMh22
Dec 2, 2005 06:19 AM
AZNBIGPIMPN505
16
Feb 10, 2005 11:00 PM
4g4me
Oct 14, 2004 03:50 PM
