B16B Civic Type R
Old Aug 26, 2003 | 09:17 AM
-KangaRod-'s Avatar
Default B16B Civic Type R
Hey,
I reciently heard a vicious rumor that a B16B is infact not using a B16A bottom end, instead a B18C bottom end, with B16A crank and longer rods. Any truth to this guys?
Old Aug 26, 2003 | 09:24 AM
dkim48's Avatar
Default Re: B16B Civic Type R (-KangaRod-)
It has the same deck height as a b18c but its not a b16a crank its a b16b crank. Just a destroked GSR crank with longer rods. Do a search next time this has been covered many times before. HTH
Old Aug 26, 2003 | 09:28 AM
TECH43 RACING INC.'s Avatar
it is true. a b16b is a b18c block (p72), a 77mm (b16a) crank, but has wider, gsr rod journals, longer rods. and a b16a head. its basically a high revving, road race type engine from the factory. the piston sits in the hole because of the taller deck height, this is also the reason for the big dome piston that gets the compression to only 10.8 to 1. many people to not understand this, and then use these pistons in engines like b18's and the compression ends up being too high for pump gas.
LS-Rman
18
Feb 11, 2013 05:56 AM
flavio
Aug 16, 2009 10:31 AM
amadriga
Sep 4, 2007 02:58 PM
DC2 Mang
12
Mar 9, 2006 05:47 PM
xci_ed6
Dec 13, 2003 10:14 PM
