Code 43 persists
Old Aug 26, 2003 | 08:39 AM
specie's Avatar
Default Code 43 persists
Had a swap in the car for 2 weeks, fuel pressure was at 47psi (Walbro pump with stock fpr). I changed out my steering wheel and removed the airbag, and started getting code 43. I guess it's just a coincidence. Drilled fpr so it's now at 40psi (with vacuum hose on). Changed fpr (3) and fuel injectors, still have the code. Changed out 1st 02 sensor (had extra) and still got code 43. Changed it again, and it ran code-free for about 3 days, then the CEL came on again. This time I got code 1, 3, and 43. Changed the 02 sensor and map sensor, now I still have a code 43.
Any ideas? ECU?
Old Aug 26, 2003 | 10:16 AM
blackeg's Avatar
Default Re: Code 43 persists (specie)
i get that damn code every once in a while after i swapped my header and o2 sensor. there were a few threads goin on about this a few months ago, but if i remember correctly a few of them never got solved...do a search and see what other people came up with, cause i cant directly help...good luck
Old Aug 26, 2003 | 12:33 PM
specie's Avatar
Default Re: Code 43 persists (blackeg)
Thanks. I tried a search already but didn't read anything that would've worked. Maybe it's a sign to start my buildup.
jdmd15crx
Aug 18, 2016 06:45 PM
LoseRPunKx182
Aug 4, 2005 01:50 AM
ImThatGuy
Jul 8, 2005 08:02 AM
foesicks
Jun 4, 2003 09:47 AM
