Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
test fitting new motor... K -> EG
Old Aug 26, 2003 | 08:31 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default test fitting new motor... K -> EG
looks pretty roomy.
Old Aug 26, 2003 | 08:52 AM
Littleton's Avatar
Default Re: test fitting new motor... K -> EG (GhettoRacer)
Let me know how you work out the replacement of the suspension.
Old Aug 26, 2003 | 09:13 AM
fireant's Avatar
Default Re: test fitting new motor... K -> EG (Littleton)
Old Aug 26, 2003 | 09:39 AM
SloCivicHMM's Avatar
WOW....really roomy......yeah what about the suspension will all that light up correctly??
Old Aug 26, 2003 | 12:28 PM
jg's Avatar
jg
all-motor drag car, maybe?
No radiator support or cowl will make an h22 look like it has space...
Old Aug 26, 2003 | 01:00 PM
eh2 nihonjin's Avatar
wow let me buy that bumper
Old Aug 26, 2003 | 01:15 PM
jsi's Avatar
jsi
Clearance looks a little tight on the pass side shock tower. Now slap on a couple of wheels and take that sucka for a spin, Bond style (trivia: which movie?). Prolly hit 12s with the stock motor...
Old Aug 26, 2003 | 01:30 PM
743power's Avatar
Default Re: test fitting new motor... K -> EG (jg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">all-motor drag car, maybe?
No radiator support or cowl will make an h22 look like it has space...</TD></TR></TABLE>
The K motors are actually quite a bit lighter than b motors and their aftermarket support and hp improvements are incredible for the amount of time they have been out. They're actually a bit smaller in dimension than a b-series motor, I think the 6spd tranny is even comparable in size to 5spd b series.
Old Aug 26, 2003 | 01:32 PM
Aquafina's Avatar
Default Re: test fitting new motor... K -> EG (743)
Maybe I should rethink building a B20/VTEC.....
Old Aug 26, 2003 | 01:42 PM
Cal's Avatar
Cal
Give the K series five years and it will be the most common swap for any Honda. They are truly great engines.
Old Aug 26, 2003 | 06:15 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">The K motors are actually quite a bit lighter than b motors and their aftermarket support and hp improvements are incredible for the amount of time they have been out. They're actually a bit smaller in dimension than a b-series motor, I think the 6spd tranny is even comparable in size to 5spd b series. </TD></TR></TABLE>
85 lbs ligher, and 225 whp with bolt-ons, street cams (toda a's) and ECU reflash.
Imagine what good headwork, race fuel, sgt tuned hondata and race cams is going to bring out... my money is on 250 reliable whp. Just disgusting.
Old Aug 26, 2003 | 06:56 PM
Timmah!!'s Avatar
Default Re: test fitting new motor... K -> EG (.RJ)
Do they use a multi-stage IM like the GSR did??
They do look very nice, but I think that there will be probles with most of the suspension, and drive train. But thats nothing a plasma cutter and a welder cant fix
Old Aug 26, 2003 | 06:57 PM
.RJ's Avatar
.RJ
Default Re: test fitting new motor... K -> EG (azroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">They do look very nice, but I think that there will be probles with most of the suspension, and drive train. But thats nothing a plasma cutter and a welder cant fix </TD></TR></TABLE>
Nothing the proper motor mounts wont fix.
Old Aug 26, 2003 | 06:59 PM
RyanR's Avatar
That front bumper looks familar. Now that I think about it, so does that front clip.
Old Aug 26, 2003 | 07:03 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Nothing the proper motor mounts wont fix.</TD></TR></TABLE>
Thats the easy part. Getting the correct CVs fot the transmition to be able to work with the splines of th hub, and having the proper length for the axles will be hard.
http://www.hasport.com/News/Articles/ESK1.htm
And that is just for a swap into car that already has a K series moto-r in it.
Old Aug 26, 2003 | 08:03 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">And that is just for a swap into car that already has a K series moto-r in it. </TD></TR></TABLE>
The 01+ civic coupes still have a d-series motor.
Old Aug 27, 2003 | 12:12 AM
216.226.142.95:27016's Avatar
mount it to the chassis then then pm me how the engine mount was made
Old Aug 27, 2003 | 05:30 AM
Brian*'s Avatar
Default Re: test fitting new motor... K -> EG (216.226.142.95:27016)
Looks like it works, they just don't want you to see how to make the mounts (note the "white out")
Brian
Old Aug 27, 2003 | 05:49 AM
carl_aka_carlos's Avatar
Default Re: test fitting new motor... K -> EG (Brian*Blue95M3)
that is ******* sick! it was bound to happen.....the K series will be the NEW new SBC
Old Aug 27, 2003 | 05:56 AM
stevel's Avatar
i believe i remembered reading that integra axles fit. Not sure on that but pretty positive. Doesn't seem that difficult actually if the axles work. I think the biggest bitch is getting the shift linkage right, wiring it, and then being able to get a dealer to disable the immobilizer for you.
s
p.s. can't wait to see the first K series powered EG or EK hatch in H1 HC! That thing is gonna be rollin some cars!!
Old Aug 27, 2003 | 07:02 AM
DROOOL.....guesss what I want now?? haha
Old Aug 27, 2003 | 07:52 AM
clm's Avatar
clm
Default Re: test fitting new motor... K -> EG (SlowCivicHmm)
Those ITBs look mean.
So I assume this will be an H1 car?
Old Aug 27, 2003 | 08:03 AM
SPiFF's Avatar
Default Re: (Cal)
Man .. that EG looks nice. Can't wait for the K24 bottom end + DC5R head H1 car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cal &raquo;</TD></TR><TR><TD CLASS="quote">Give the K series five years and it will be the most common swap for any Honda. </TD></TR></TABLE>
SPiFF reconsiders his TSX or RSX-S purchase.
Old Aug 27, 2003 | 08:49 AM
Doctor CorteZ's Avatar
drool.
I have K fever
Old Aug 27, 2003 | 08:59 AM
Austin's Avatar
Imagine what good headwork, race fuel, sgt tuned hondata and race cams is going to bring out... my money is on 250 reliable whp. Just disgusting.</TD></TR></TABLE>
HyTech has a 267/173 on 91 octane, still making revisions to the header, cam profiles, and intake manifold.
12:1 compression Pistons(allowable in Speed TC)
Rods
HyTech cams
HyTech springs
HyTech Ti retainers
Endyn headwork
HyTech header
HyTech exhaust
HyTech intake manifold
HyTech intake
Hondata
HyTech is currently working on a built NA 2.3L, and cams and headers for the stock compression, as well as a Supercharger and Turbo kit as well. He would love to road race one, but the budget isn't there, as he's currently working on a NA NHRA drag car with the RSX engine.
Austin - just with the inside track on the HyTech RSX products
