PST front end kits , any good ?
Does anyone here have experience with the front end kits from http://www.p-s-t.com./ ? Seems like a good deal if the quality is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R »</TD></TR><TR><TD CLASS="quote">they look pretty good, they just use graphite bushings instead of urethane ones</TD></TR></TABLE>
They are polygraphite so basically poly impregenated with graphite.
I installed the entire kit recently. It was a Pain , but the rewards were great. Notice that the kit replaces the tie rods and the ball joints. I would NOW recommend installing a camber kit, brake lines, new brake rotors, brake pads, swap belts and change pulleys if you can at this time. ( you will have everything on the front end apart anyway) I am having huge toe problems right now and haven't gotten an alignment till more money rolls in. I give it a 8 out of 10 for worth, but 7 out of 10 for difficuilty and time comsumption. (10/10 is a hybrid swap)
Type X
Honda Civic (2006 - 2015)
40
Nov 12, 2006 06:09 AM
