Axle stuck on B16
Old Aug 25, 2003 | 08:23 PM
purpl7duece's Avatar
Default Axle stuck on B16
The driver side axle is stuck on my friends 99 b16. The boot piece is stuck in there. Part of the shaft is out but the end piece is still in there. Any help is appreciated.
Old Aug 25, 2003 | 08:33 PM
mntuner2's Avatar
Default Re: Axle stuck on B16 (purpl7duece)
pry bar, um patience. if that doesn't work try air chisel w/dull blunt wedge like bit(That is if you tried many long hours trying to remove it with a pry bar.)
Old Aug 26, 2003 | 07:27 AM
2camsaam's Avatar
Default Re: Axle stuck on B16 (mntuner2)
I bought a crow bar from Home Depot for this issue and it worked like a charm.
Old Aug 26, 2003 | 08:31 AM
IN VTEC's Avatar
I always use a pry bar and hit the pry bar with a small sledgehammer to leverage it out.
Old Aug 26, 2003 | 10:37 AM
TwoRedEGgs's Avatar
Default Re: Axle stuck on B16 (IN VTEC)
yep, this is true they like to stay in there hole for as long as they can, but once they see that bar they pop right out !!!
good luck man!!
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Quetzolcotl
May 9, 2006 06:04 PM
*Boostwerks*
34
May 7, 2006 10:29 PM
2k1_ITR_0736
14
Jan 13, 2003 10:48 PM
20lb.teg
Oct 8, 2002 09:13 PM
