how to install and wire side marker
Old Aug 25, 2003 | 07:28 PM
99lsvtecauto's Avatar
Default how to install and wire side marker
i just bought some apc side marker i was wondering the best way and location to mount and wire them and what to wire them to for power
Old Aug 25, 2003 | 08:56 PM
5DegAdv's Avatar
Default Re: how to install and wire side marker (99 ls integra)
4" above centered to your moulding
Old Aug 25, 2003 | 09:01 PM
5DegAdv's Avatar
Default Re: how to install and wire side marker (jfoxmatt71)
wire them to your blinkers, you want them to blink opposite of your blinker...like when front blinker blinks, side marker blinks off.. this might not make sence but you want like a wig-wag effect. you need a relay.
Old Aug 25, 2003 | 11:00 PM
XxLuckyLisaxX's Avatar
or you could/should make a template so the side markers are in the exact spot on both sides
Old Aug 26, 2003 | 12:23 AM
illusive's Avatar
Default Re: how to install and wire side marker (XxLuckyLisaxX)
Easy why measure out where you want them to go measure two, three times cut and drill only once. I found the easiest way is to wire it to the corner blinker bulb. I used a metal coat hanger and striaghtened it out and taped the wire to the end of it and threaded it through the hole and out where the corner lamp was.
Old Aug 26, 2003 | 05:18 AM
USDM 4G VTEC's Avatar
get real Stanley SiR sidemarkers...
dont go rice
but anyways i did a writeup on where i put mines...
http://www.geocities.com/chacofgs/mods.html
Old Aug 26, 2003 | 05:42 AM
Honda Bob's Avatar
Default Re: how to install and wire side marker (USDM 4G VTEC)
Make sure when you drill the holes to use a really sharp good bit. I have a brand new set of Dewault metal bits that I love. And don't put a lot of pressure into the drill or you could easily dent your fender.
Hoep this helps and was not too late.
xander1100
Mar 1, 2009 04:02 PM
buzzsawstan
Jun 30, 2004 09:09 PM
99lsvtecauto
Aug 26, 2003 06:06 AM
