how to install and wire side marker
Old Aug 25, 2003 | 07:47 PM
99lsvtecauto's Avatar
Default how to install and wire side marker
just bought some apc side marker i was wondering the best way and location to mount and wire them and what to wire them to for power so that they will flash when turn signals flash . this is on an l s 4dr
Old Aug 25, 2003 | 08:12 PM
B16OnTop's Avatar
Default Re: how to install and wire side marker (99 ls integra)
i searched and got 136 results found for 'Sidemarkers'
Old Aug 25, 2003 | 08:37 PM
Audi A4's Avatar
Default Re: how to install and wire side marker (B16OnTop)
wire them p tp your turn signals
Old Aug 25, 2003 | 08:38 PM
IntEGNYC's Avatar
check for placement on other integras under the appearance forum.
Old Aug 25, 2003 | 08:55 PM
jonoknut's Avatar
Default Re: how to install and wire side marker (IntEGNYC)
i shouldnt help you just becasue they are apc sidemarkers, haha but, you need to tap the wires to the front conrenr blinkers. you can wire them to be on all the time with the headlights, or just as blinekrs yada yadqa i really odnt remeber which color is which, but it took me about 10 times to get it right, theres a few wires to work with, but i can tell u now black is your ground, and i belive u tap the high voltage (green?) that is to the front bulb, not the side one. good luck, if u search hard enough there are enough threads that tell how.
Old Aug 25, 2003 | 08:59 PM
tegasaurus's Avatar
Default Re: how to install and wire side marker (jonoknut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonoknut &raquo;</TD></TR><TR><TD CLASS="quote">i shouldnt help you just becasue they are apc sidemarkers, haha but, you need to tap the wires to the front conrenr blinkers. you can wire them to be on all the time with the headlights, or just as blinekrs yada yadqa i really odnt remeber which color is which, but it took me about 10 times to get it right, theres a few wires to work with, but i can tell u now black is your ground, and i belive u tap the high voltage (green?) that is to the front bulb, not the side one. good luck, if u search hard enough there are enough threads that tell how.</TD></TR></TABLE>
you just know found out that black is ground? Very nice pickup on the sidemarkers, they look great, however the whole apc thing... i dunno bout that
-ryan
Old Aug 25, 2003 | 10:46 PM
SilverDc2's Avatar
Default Re: how to install and wire side marker (tegasaurus)
dont put apc, at least get the jspec clear ones if you dislike the amber.
Old Aug 26, 2003 | 06:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Step 1: take those APC sidemarkers back and get your money back if you can
Step 2: buy OEM DC Integra sidemarkers
Step 3: search to find out how to make the holes and hook them up
Step 4: use this diagram to get the placement correct:
90_EX_Civic
Mar 21, 2009 07:59 PM
97tegblk
Lighting
Sep 25, 2007 02:19 AM
ATL_gingerkid
Feb 17, 2007 10:46 AM
99lsvtecauto
Aug 26, 2003 05:42 AM
Trigun
Apr 18, 2002 03:26 AM
