CTR Pistons with TODA B's
Old Aug 25, 2003 | 06:42 PM
Aceman64's Avatar
Default CTR Pistons with TODA B's
CTR Pistons, TODA B cams, and TODA Cam Gears on a B18C1. The TODA gears can only be adjusted plus or minus 5 degrees in each direction. Anyone who has this setup and has tuned the gears, how many degrees did you go? Anyone have piston to valve clearance issues while advancing or retarding the gears?
Any help would be greatly appreciated.
-Ace
Old Aug 25, 2003 | 07:00 PM
NSX Bob's Avatar
New User
Default Re: CTR Pistons with TODA B's (Aceman64)
The furthest either of mine are tuned is -4, this is Toda B's w/ ctr pistons on a b18c5. That is not to say they can't go further, that just happens to be where one of mine is set.
Old Aug 26, 2003 | 05:49 AM
Ausmith's Avatar
Default Re: CTR Pistons with TODA B's (Type R Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">The furthest either of mine are tuned is -4, this is Toda B's w/ ctr pistons on a b18c5. That is not to say they can't go further, that just happens to be where one of mine is set.</TD></TR></TABLE>
C1 and C5 combustion chambers are different... be aware.
Old Aug 26, 2003 | 10:34 AM
NSX Bob's Avatar
New User
Default Re: CTR Pistons with TODA B's (Ausmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">
C1 and C5 combustion chambers are different... be aware.</TD></TR></TABLE>
Exactly, which is why I said my set-up was on a c5. Don't know how much of a difference the c1 makes w/ this set-up, so I really can't elaborate.
Old Aug 26, 2003 | 11:33 AM
Aceman64's Avatar
Thank you for the input so far.
-Ace
Old Aug 26, 2003 | 06:14 PM
chad's Avatar
Moderator
DEGREE the cams in.....and don't adjust more than 1 degree when on the dyno for testing.....toda has done all the work for you and their settings are almost always dead on if you degree the cams in!!!!!!!!!!!!!!!!!
Old Aug 26, 2003 | 11:26 PM
ill phil's Avatar
Default Re: CTR Pistons with TODA B's (chad)
I still don't know how to degree cams properly but I hear Cheetah (I believe) suggest the same with Toda cams as far as tuning.
Old Aug 27, 2003 | 05:57 AM
Aceman64's Avatar
Default Re: CTR Pistons with TODA B's (ill phil)
Ok, I found out they can be adjusted up to 5 degrees in either direction. Thanks again for the input.
-Ace
AllMotorDan
12
Aug 8, 2011 03:00 PM
totsie7944
Sep 23, 2005 03:01 PM
Aceman64
Aug 29, 2003 02:11 PM
Aceman64
Aug 26, 2003 11:20 AM
