CTR Pistons with TODA B's
Old Aug 25, 2003 | 06:41 PM
Aceman64's Avatar
Default CTR Pistons with TODA B's
CTR Pistons, TODA B cams, and TODA Cam Gears on a B18C1. The TODA gears can only be adjusted plus or minus 5 degrees in each direction. Anyone who has this setup and has tuned the gears, how many degrees did you go? Anyone have piston to valve clearance issues while advancing or retarding the gears?
Any help would be greatly appreciated.
-Ace
Old Aug 26, 2003 | 07:14 AM
Spoond TEG's Avatar
Default Re: CTR Pistons with TODA B's (Aceman64)
I could have sworn I saw this EXACT SAME thread some place else.
Old Aug 26, 2003 | 09:43 AM
FastSS's Avatar
valves? springs? retainers?
Old Aug 26, 2003 | 11:19 AM
Aceman64's Avatar
Default Re: CTR Pistons with TODA B's (FastSS)
Stock valves.
-Ace
Old Aug 28, 2003 | 03:46 PM
EGRhatch's Avatar
Default Re: CTR Pistons with TODA B's (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">I could have sworn I saw this EXACT SAME thread some place else.</TD></TR></TABLE>
You know... so did I,
Tech Forum
Type R foum
All motor Forum
and this one... how many threads do you need to create??
Old Aug 28, 2003 | 03:49 PM
ncVTEC1313's Avatar
thats the setup im looking at starting, do you like it?
Adam
Old Aug 28, 2003 | 05:55 PM
Aceman64's Avatar
Default Re: CTR Pistons with TODA B's (EGRhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Tech Forum
Type R foum
All motor Forum
Notice how it fits in all of the categorys. Well different people frequent different categorys so you will get more responses. Just like how it got 8 replys in one and 0 in another.
-Ace
Old Aug 29, 2003 | 01:19 PM
IN VTEC's Avatar
Is the motor already in the car? Last time I saw it, it was still on the stand about a year ago.
You can use a check spring and a dial indicator to check the valve clearances at and around TDC on the exhaust stroke and intake stroke as you advance (intake)/retard (exhaust) the cams.
Old Aug 29, 2003 | 01:23 PM
Aceman64's Avatar
Default Re: CTR Pistons with TODA B's (IN VTEC)
Yeah, its finally in there. Havent driven it yet, still messing around. It just came to mind about how much could I adjust them so I figured I would ask instead of taking the head off.
-Ace
Old Aug 29, 2003 | 01:39 PM
IN VTEC's Avatar
PM or IM me later on tonight if you're not busy and I'll do my best to reason things out with you.
bchang378
Old Aug 29, 2003 | 02:11 PM
Aceman64's Avatar
I ended up figuring it out. I am able to go 5 degrees in either direction and be ok. Thank you though.
-Ace
AllMotorDan
12
Aug 8, 2011 03:00 PM
totsie7944
Sep 23, 2005 03:01 PM
Aceman64
Aug 27, 2003 05:57 AM
Aceman64
Aug 26, 2003 11:20 AM
