how do you fix code 14?
Old Aug 25, 2003 | 05:34 PM
untitled's Avatar
Default how do you fix code 14?
once the CEL is triggered the thing idles crazy. it goes up then falls real quick like i let off the accelerator and then goes back up without letting my foot off. im thinking IACV??? any way to fix it?
Old Aug 25, 2003 | 10:35 PM
salbaje's Avatar
Default Re: how do you fix code 14? (lstegwithvtec)
replace it??
Old Aug 26, 2003 | 08:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lstegwithvtec &raquo;</TD></TR><TR><TD CLASS="quote">... any way to fix it?</TD></TR></TABLE>Take it off & clean it with TB cleaner. Check for flaky wiring connections??
Old Aug 26, 2003 | 08:46 AM
untitled's Avatar
Default Re: how do you fix code 14? (JimBlake)
it worked fine before swap. itsa d16z6 in a 89 si wired obd0 with zdyne gold ecu.
Old Aug 26, 2003 | 09:30 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lstegwithvtec &raquo;</TD></TR><TR><TD CLASS="quote"> itsa d16z6 in a 89 si wired obd0 with zdyne gold ecu.</TD></TR></TABLE>
where did you wire up the mapsensor ? its not part of the engine harness its on the firewall on passenger side. connect vaccum to stock location map sensor and use that instead of the d16z6 map sensor on TB
greg
Old Aug 26, 2003 | 09:42 AM
untitled's Avatar
Default Re: how do you fix code 14? (CHEETAH)
i am using a completly diferent map sensor. im not using the one on the tb or the one on the firewall. i think ity has that gm 3 bar one . it has 1 red, 1 black, and one white wire. there is no plug plugged into either factory map sensor.
Old Aug 26, 2003 | 01:37 PM
untitled's Avatar
madswapper
May 29, 2005 12:43 PM
Cappelle
Apr 28, 2005 04:37 PM
teefunk01
Apr 20, 2005 04:32 PM
Pete_SI
Mar 22, 2005 03:12 AM
sohcvtec1995
14
Sep 23, 2004 11:12 AM
