turbo h22 in a accord wagon having problems with redline only hitting 6500.
Old Aug 25, 2003 | 05:01 PM
holeymoly's Avatar
Default turbo h22 in a accord wagon having problems with redline only hitting 6500.
Car redlines at 6500rpm its like it has a rev limiter. It sputters aggressively. Have hi flow in line fuel pump.
Old Aug 27, 2003 | 09:08 PM
All-MotorSports's Avatar
Default Re: turbo h22 in a accord wagon having problems with redline only hitting 6500. (kctuner)
Check the ground for the vtec wiring. I had the same problem in my old hybrid Accord when I first got it done.
Old Aug 27, 2003 | 10:51 PM
slrh22hatch's Avatar
Default Re: turbo h22 in a accord wagon having problems with redline only hitting 6500. (PIMPASSBEOTCH)
Your a ****** punk. ****** hater!!
Old Aug 27, 2003 | 11:19 PM
haahahaha
Old Aug 29, 2003 | 09:09 AM
dominate9's Avatar
Default Re: turbo h22 in a accord wagon having problems with redline only hitting 6500. (All-MotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-MotorSports &raquo;</TD></TR><TR><TD CLASS="quote">Check the ground for the vtec wiring. I had the same problem in my old hybrid Accord when I first got it done.</TD></TR></TABLE>
I agree. Sounds like you are using an AFC. Check your wiring. Make sure the VTM wire from the AFC is hooked up.
Old Aug 29, 2003 | 06:05 PM
holeymoly's Avatar
I got that **** set up tommorow and that peice will be sold. Then I going to find your punk *** and put my foot in your anus and 5000$ with it. Then my friend its on. The litte giper will be mine. So I will help you put that dash in.
Thanks for blowing my cover now I look like a litte bitch with a wannbe import.
SOLID SNOOTCH
96H22CD7
Aug 13, 2007 04:18 AM
khunt0012
Apr 5, 2006 09:56 AM
tylek17
Dec 19, 2003 08:17 AM
polycrx
Apr 27, 2003 03:50 PM
