help takeing off stickers?????
Im thinkin of takeing off all the stickers on my trunk the prelude, dohcvtec and the sh sticker. Whats the best way of takeing them off without fuking up the paint ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeReasons »</TD></TR><TR><TD CLASS="quote">user your fingers.. thats what i did.. </TD></TR></TABLE>
blow dryer and goo gone.
for the bumper sticker, try using floss or fishing line.
don't heat it too long, it could ruin your paint.
i believe this topic was covered a few times already, did you try searching first?
thanks for the info guys yes i thought there was a post about this and i did use search but nothing came up, any one else have tips about takeing off the emblem???
the emblem: use a flathead screwdriver. wrap the head in a towel or newspaper and just pry it off. i recommend a towel because the newspaper can rip.
note: you will see two plastic pieces after removing the emblem. you can remove it with a needle nose but there'll be two holes.
still be careful with the screwdriver. if you can find a plastic putty knife that is what i would use. it will give on impact to the paint where a screwdriver would not. it may be a bit harder to do that way but i find it to be safer to the paint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro »</TD></TR><TR><TD CLASS="quote">Is there a way to fill in the 2 holes in the front bumper??
Some ******* stole my front badge along with my wheel balancing weights.</TD></TR></TABLE>
fiberglass kit. pick that up at a boaters supply store. bondo. then touch up the paint.
Okay. I was just thinking that the fiberglass might not work too well on the plastic. Like if someone or something pushed on the bumper I thought it might crack since the fiberglass is stiffer than the plastic.
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
SleekBlkPrelude
Jul 17, 2003 03:29 PM
