Side Marker Placement
Old Aug 25, 2003 | 03:09 PM
Clutch101's Avatar
Default Side Marker Placement
Does anyone have the correct location for the CTR Side Markers. Have some and would like to install them in the correct location. If anyone has CTR fenders, could you please measure the cut-outs.
Any information would be helpful.
Thanks.
Old Aug 25, 2003 | 03:29 PM
slvrcivic97's Avatar
Default Re: Side Marker Placement (JDMwannaB)
1. Make a line from the front of the sideskirts up to the top of the fender.
2. Make a line that extends from the top center of the wheel well.
3. Where those 2 lines intersect is where the middle of you sidemarker should be.
4. Cover the arear where the sidemarker is going to go with clear tape before you do any cutting to prevent paint chippage. Drill a starter hole carefully on the dot.
5. Use a metal nibbler found at radio shack for 10 bux to do the cutout. It takes a while, but it will turnout clean.
6. *Tips*
-Put some touch up paint if you have some laying around the edges of the bare metal.
-After you test fit the sidemarker and it pops in, put some plummer's putty around the crack to keep all the water out
-Remember you can always take some metal off, but you can't add it so test fitting the piece often is in your best interest.
Here's a pic of when I did mine:
Installed:
Modified by slvrcivic97 at 12:40 AM 8/26/2003
Old Aug 25, 2003 | 03:41 PM
Clutch101's Avatar
Default Re: Side Marker Placement (slvrcivic97)
Thank you very much slvrcivic97.
jeb.'s Avatar
Thanks for the good write up. I was looking for clear info on this for a while.
Old Aug 25, 2003 | 03:42 PM
foofighter's Avatar
perfect! btw are those the real deal sidemarkers?
Old Aug 25, 2003 | 03:45 PM
Default Re: (foofighter)
Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foofighter &raquo;</TD></TR><TR><TD CLASS="quote">perfect! btw are those the real deal sidemarkers?</TD></TR></TABLE>
Yeah. I purchased them from icb motorsports-They come with the sockets and bulbs :
Old Aug 25, 2003 | 04:02 PM
Filliam H. Muffman's Avatar
Default Re: (slvrcivic97)
so thats the OEM spot?
Old Aug 25, 2003 | 04:11 PM
hazard_one's Avatar
i dont think so...but it looks nice!
Old Aug 25, 2003 | 04:46 PM
cccya's Avatar
Default Re: (Trunks714)
hers the oem spot on the EG6..
Old Aug 25, 2003 | 04:51 PM
Default Re: (cccya)
Yeah, the eg and ek are different spots. I'm assuming you wanted the ek ctr.
Old Aug 25, 2003 | 05:07 PM
JDMy0's Avatar
141.217.174.219
got a link to icb motorsports ? im interested in a set
Old Aug 25, 2003 | 05:46 PM
Default Re: (JDMy0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMy0 &raquo;</TD></TR><TR><TD CLASS="quote">got a link to icb motorsports ? im interested in a set</TD></TR></TABLE>
Yup, here it is:
http://www.icbmotorsport.com/
Old Aug 28, 2003 | 10:47 PM
foofighter's Avatar
thanks for the link!
Old Aug 28, 2003 | 11:07 PM
RangerDan's Avatar
Good info
Old Aug 29, 2003 | 07:10 AM
BLKWIDOW's Avatar
Sweet write up!! Seems like a fairly inexpensive mod! How difficult is the wiring? Also, do you recall what size hole you originally drilled?
Old Aug 29, 2003 | 08:10 AM
stockegsix's Avatar
Default Re: Side Marker Placement (BLKWIDOW)
you dont drill, you cut. wiring is easy if you want it to just go on when you signal, tap the green and black wire from the corner lights.
Old Aug 29, 2003 | 08:29 AM
BLKWIDOW's Avatar
Default Re: Side Marker Placement (zzZZzzleeperCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzZZzzleeperCX &raquo;</TD></TR><TR><TD CLASS="quote">you dont drill, you cut. wiring is easy if you want it to just go on when you signal, tap the green and black wire from the corner lights.</TD></TR></TABLE>
What about the starter hole?? How would you cut that out?
Old Aug 29, 2003 | 09:21 AM
foofighter's Avatar
First and foremost use masking tape and tape off the area that you will be drilling and cutting. Minimizes the paint from chipping etc. Also makes it easier to draw out the outline of what you want to cut.
start w/ a pilot hole. use one of those cone-shaped-stepped reaming drill bit then you can get the hole bigger.
Then follow the rest of the write up or if you're really good use a dremel tool but be very very careful...one slip and that cutting wheel is going to do some travelling
Old Aug 29, 2003 | 09:31 AM
BLKWIDOW's Avatar
Default Re: Side Marker Placement (foofighter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foofighter &raquo;</TD></TR><TR><TD CLASS="quote">First and foremost use masking tape and tape off the area that you will be drilling and cutting. Minimizes the paint from chipping etc. Also makes it easier to draw out the outline of what you want to cut.
Then follow the rest of the write up or if you're really good use a dremel tool but be very very careful...one slip and that cutting wheel is going to do some travelling </TD></TR></TABLE>
Thanks!!
VTECROAR96typeR
Paint and Body
Mar 2, 2009 02:08 PM
not2fast
May 10, 2006 05:48 PM
t o m
May 18, 2004 07:17 AM
BlackCivicHatch
Dec 4, 2003 12:46 AM
SOJAMR1
Jan 5, 2003 01:17 PM
