Turbo and VTEC
Old Aug 25, 2003 | 12:27 PM
Slvr_CRX's Avatar
Default Turbo and VTEC
Ok. i was wondering. Someone told me that if you have vtec that getting turbo for it isnt as good as getting turbo for non vtec? this is what this guy told me that you can only use 25% of the turbo and its hard to tune is that right? cuase i'm about to get a b16a engine and i want to make sure its the right choice?
Old Aug 25, 2003 | 12:35 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
vtec is good.....but you are usually boostin before vtec even kicks in.....it depends on what you set your vtec too....
Old Aug 25, 2003 | 02:56 PM
Will Albers's Avatar
Default Re: (dgonzals)
VTEC and turbo is a tried and true combination... There are some disadvantages due to the flow of the vtec cam though. It actually allows for quite a bit of boost to blow by, lowering the potential output of the turbo. Since the vtec engines usually have more power than a non-vtec block, its usually fine. Basically if a vtec and non vtec made the same amount of power, using the same turbo on a non vtec engine would give you more power.... but thats simply not the case.
Yes Vtec will add more to the tuning process, but it will take to a turbo just fine. In fact a good set of turbo vtec cams can do wonders
WaynePlayer
Oct 26, 2017 07:44 AM
WaynePlayer
Oct 26, 2017 06:37 AM
xSOHC
May 24, 2012 06:49 AM
walsh22
Apr 3, 2007 12:42 PM
dayaftertomorrow
May 2, 2005 01:41 PM
