Camber Kit..
From: Put it in..Take it out... Put it in..Take it out, United States
I just got a set of Skunk2 coilovers and i want to know.. what is the best camber kit that doesn't cost alot... kinda low on money... and if it helps i have a 92 civic VX
i had an ingalls kit on my crx... worked really good for the money... i got mine for $130 shipped... those adjustable ball joint style kits catch my attention also, but are a bit more pricey... skunk2 makes a nice one
I currently have an ingalls kit, but to get my camber correct my upper A arm is so far out that when I turn really hard, it comes in contact with the fender well.... Wonder if the SkunkII would correct that problem....
With the Ingalls kit, if you run say....2+ or more camber back, you'll hit the inner fender. Simply go and dremel taht thing out so it doesn't hit is all.
I've seen some imitation ingalls kits on ebay and i'm not sure if they work as well. The ingalls kit is very simple in design and basically should be made for much less than the $180 they retail it for.
I personally have the ingalls kit. I used the ingalls front and washers for the rear.
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
Fo-Do Fanatic
20
Feb 10, 2011 01:34 PM
