Clutch + flywheel?
Old Aug 25, 2003 | 09:33 AM
JasterM5's Avatar
Default Clutch + flywheel?
a friend and I are dropping in a b18C1 into a 89 CRX DX. If we use an Exedy Clutch with an Act Flywheel, do we have to fill in all the holes on the clutch? It came with 6 bolts and there are more holes left on the pressure plate.
Any help would be appreciated.
Old Aug 25, 2003 | 09:42 AM
im sabah's Avatar
Default Re: Clutch + flywheel? (JasterM5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasterM5 &raquo;</TD></TR><TR><TD CLASS="quote">a friend and I are dropping in a b18C1 into a 89 CRX DX. If we use an Exedy Clutch with an Act Flywheel, do we have to fill in all the holes on the clutch? It came with 6 bolts and there are more holes left on the pressure plate.
Any help would be appreciated.</TD></TR></TABLE>
you should be fine with only 6 if you have to drive that way otherwise find new bolts... if im not mistaken, there are 3 groups of three bolt holes each around the pressure plate (its like *** *** *** [in a circle of course]) make sure you put bolts on the 2 edges of each group of three - (the # is a bolt and * is the empty hole: #*# #*# #*# [again, in a circle around the pressure plate]) it should be fine but i would get bolts as fast as possible...
Old Aug 25, 2003 | 09:45 AM
Kataku2K3's Avatar
Default Re: Clutch + flywheel? (im sabah)
Yea, the older B series motors have a nine bolt pattern where as the new ones only run six... Whenever I'm working with an older flywheel and clutch that originally had a nine bolt pattern I use all NINE bolts... I'm sure six would hold just fine but that's just me... Good Luck
Old Aug 25, 2003 | 11:50 AM
JasterM5's Avatar
Ok, guys. Thanks. Will Do
-JasterM5
fwdlooser93eg
Jul 24, 2006 06:52 PM
flip1199
Nov 7, 2005 11:07 AM
DPSJosh
Aug 26, 2005 06:09 AM
