Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Going from 15" to 14" wheel/tire setup for AutoX
Old Aug 25, 2003 | 08:52 AM
Yellow Dragon's Avatar
Default Going from 15" to 14" wheel/tire setup for AutoX
HELP!!!
My CX hybrid doesn't have p/s and ever since I went to the 15" Slipstreams with sticky race tires it's starting to affect my quick steering capabilities. Curious if I go to a 14" setup with sticky race tires if this will help out and be more beneficial.
Old Aug 25, 2003 | 10:43 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: Going from 15" to 14" wheel/tire setup for AutoX (Yellow Dragon)
Really not trying to be a dick, but--Huh? Your steering is slower, or is it faster? Tire/wheel size is irrespective of steering ratio.
--Chris, who wishes he had quick-steering capabilities.
Old Aug 25, 2003 | 10:56 AM
Default Re: Going from 15" to 14" wheel/tire setup for AutoX (madhatter)
My steering "abilities" feel somewhat hindered ever since I went to a set of race tires on my 15" Slipstreams. When I still had street tires that weren't as sticky I didn't notice much.
My main question is if I should go to a 14" wheel/race tire setup.
Old Aug 25, 2003 | 11:18 AM
Def's Avatar
Def
Hit the gym and get some muscles on those skinny arms of yours.
Old Aug 25, 2003 | 11:30 AM
Mattamotor's Avatar
Put some 13x8 autox wheels on your car and drive it on the street for a week or 2 then you should be able to turn those skinny 15s any day.
Old Aug 25, 2003 | 11:36 AM
turbohappy's Avatar
It's width (and compound) of the tires that matters, wheel size doesn't matter at all.
Old Aug 25, 2003 | 12:36 PM
EF_LSVtec's Avatar
Default Re: Going from 15" to 14" wheel/tire setup for AutoX (turbohappy)
You're probably better off getting lighter wheels overall...Even if you switch to a 14 inch wheel if they're heavier than the shitstreams, then you're back to square one. Try getting a smaller diameter steering wheel too to help with response time. And I'd take up weight lifting 101 and a set of dumbells.
Old Aug 25, 2003 | 01:02 PM
GSpeedR's Avatar
Sidewall height/deflection makes a significant difference, especially if were talking about steering response.
14" have a larger sidewall, which means more deflection for the same tire, which means even worse response (in most cases!).
Old Aug 25, 2003 | 01:42 PM
Okay...hitting the gym isn't the issue people. I'm not a small guy by any means. I'm just having trouble on tight, technical courses. I don't daily drive my hatch anymore so that might be the issue...not being used to the lack of p/s.
So going to a smaller tire/wheel setup isn't the answer? I need help here people. I really want to be competitive in SM.
Old Aug 25, 2003 | 02:07 PM
Mohudsolo's Avatar
If you don't want the power drag of the p/s pump, try what some of the ep cars I have seen do and use an electric p/s pump from a Toyota MR2 or a Subaru (I forget what model). If it's legal, use a steering quickener along with the electric p/s. The quickener is a gearbox that fits between the steering wheel and shaft.
meric0786
May 6, 2010 01:28 PM
kay_animation
Jan 4, 2009 10:29 AM
exz0n-.-
Nov 27, 2008 12:19 AM
StylishDOHC
Aug 22, 2006 05:20 PM
EG8steve
Aug 26, 2002 05:34 PM
