Clicking in front end.
Old Aug 25, 2003 | 07:13 AM
danrsmith's Avatar
Default Clicking in front end.
I need some help on where to start.
1994 Honda Accord
Occasionally, especially at low speeds, there is a clicking sound from the front end while turning. Power steering pump pulley is turning and the fluid level is fine.
Any help on what to look for is appreciated.
Thanks in advance,
Dan
Old Aug 25, 2003 | 09:34 AM
gitwidit's Avatar
Default Re: Clicking in front end. (danrsmith)
may be cv joint in axle. see if it is intermittent depending on which way you turn your wheel etc.
Old Aug 25, 2003 | 09:42 AM
Kataku2K3's Avatar
Default Re: Clicking in front end. (GITWIDIT)
do you still hear the clicking when your car is stationary and the engine is running??? If it is only when you're driving I'm also guessing that the problem is somewhere in your driveline (most commonly what GITWIDIT said, an axle... If the clicking keeps going even while you're stopped then the problem probably lies in the motor... Good Luck
Old Aug 25, 2003 | 09:44 AM
im sabah's Avatar
sounds like cv joint to me...
Old Aug 25, 2003 | 11:23 AM
R6Elmo's Avatar
Default Re: Clicking in front end. (im sabah)
i vote for CV joint. I suggest jsut changing the axles
Old Aug 25, 2003 | 12:28 PM
gitwidit's Avatar
Default Re: Clicking in front end. (R6Elmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">i vote for CV joint. I suggest jsut changing the axles</TD></TR></TABLE>
werd, IMO easier, only way to go.
jjdickm
Sep 2, 2007 11:48 AM
tunerkid7
Honda Civic (2001 - 2005)
Jul 12, 2007 11:12 AM
drewhart
Apr 19, 2006 02:17 PM
rice_classic
Dec 11, 2004 05:15 AM
RotiEatter
Aug 12, 2003 12:55 AM
